Hello all,
Thank you for your great program! I have already used it several times.
Unfortunately, I got desperate at the weekend.
I wanted to flash DietPi on an SD card with V 1.7.9 under Windows 10 (as usual). At the end I always got a “flash failed” message.
On the same laptop, same SD card, same SD slot, same image, I tried it under Linux Mint (dual boot with windows). Here it ran through directly on the first try.
What could have been the problem here?
Greetings ![]()
