Flash failed need help
I having the same problem. verification fails at 15% when flashing octopi v.17.
Am I fine to use the SD card, even though the verification failed? will the “System Volume Information” partition windows automatically created cause any problems? Or is there a way to prevent it so verification completes?
I have found a solution. See the answer here https://superuser.com/questions/1199823/how-to-prevent-creation-of-system-volume-information-folder-in-windows-10-for/1199824#1199824 as well as the next answer down.
I had to disable both Windows Search and Storage Service, as well as create the DisableRemovableDriveIndexing DWORD value in regedit.
I can now flash and verify octopi v0.17 successfully
I am seeing this issue but from what I can see it is definitely related to using a USB SD Card adapter or not. Meaning, I tried 2 different USB micro SD card adapters, both failed during verification and disk seemed corrupt at end. However, when I used a built-in SD card reader on my work laptop, it worked fine (also considerably faster, if it matters). My failed log below for one of USB adapters:
Version = 1.5.113, Type = nsis
gui.js:64184 Mon Jan 11 2021 21:21:19 GMT-0500 (Eastern Standard Time) Application start ({“packageType”:“nsis”,“version”:“1.5.113”,“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Mon Jan 11 2021 21:21:31 GMT-0500 (Eastern Standard Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Mon Jan 11 2021 21:21:34 GMT-0500 (Eastern Standard Time) Select image ({“image”:{“size”:2489319424,“name”:“2020-12-02-octopi-buster-armhf-lite-0.18.0.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:2216689664,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\danga\OneDrive\Documents\2021-01-11_2020-12-02-octopi-buster-armhf-lite-0.18.0\2020-12-02-octopi-buster-armhf-lite-0.18.0.img”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Mon Jan 11 2021 21:21:39 GMT-0500 (Eastern Standard Time) Toggle drive ({“drive”:{“size”:62209916928,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Mon Jan 11 2021 21:21:40 GMT-0500 (Eastern Standard Time) Flash ({“image”:{“size”:2489319424,“name”:“2020-12-02-octopi-buster-armhf-lite-0.18.0.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:2216689664,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\danga\OneDrive\Documents\2021-01-11_2020-12-02-octopi-buster-armhf-lite-0.18.0\2020-12-02-octopi-buster-armhf-lite-0.18.0.img”},“drives”:[{“size”:62209916928,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“2d2cd3e6-f7be-49e0-8ab5-765cdb005da8”,“status”:“started”,“flashInstanceUuid”:“2d2cd3e6-f7be-49e0-8ab5-765cdb005da8”,“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Elevating command: C:\Users\danga\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\danga\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
gui.js:6038 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:56886 Mon Jan 11 2021 21:21:42 GMT-0500 (Eastern Standard Time) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://assets.balena.io/etcher-featured/index.html?borderRight=false&darkBackground=true&etcher-version=1.5.113&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1610418102143.079,“resourceType”:“mainFrame”,“ip”:“172.67.149.103”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:["*"],“age”:[“536”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“610367d2ed38fec2-IAH”],“cf-request-id”:[“0795ff37d60000fec27b2cf000000001”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Tue, 12 Jan 2021 02:21:42 GMT”],“expect-ct”:[“max-age=604800, report-uri=“https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct””],“expires”:[“Sun, 10 Jan 2021 07:01:44 GMT”],“last-modified”:[“Thu, 17 Dec 2020 22:56:48 GMT”],“nel”:["{“report_to”:“cf-nel”,“max_age”:604800}"],“report-to”:["{“endpoints”:[{“url”:“https:\/\/a.nel.cloudflare.com\/report?s=10x21l3WiA3afR78nThmbgr2KyPWWto2cJM7Y%2BWgf2MuuQJKuoZuzRZmlI%2Bi18L4YvWpIxjotYjTOv0j8zO71hkq6X7Hkwa1a8QLTe%2Bw7sb8”}],“group”:“cf-nel”,“max_age”:604800}"],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“c177f452461c12ca788d2a05c7e9717e93ef7bc5”],“x-github-request-id”:[“B0C6:5669:3F1C38:4CAABA:5FFAA5B4”],“x-proxy-cache”:[“HIT”],“x-served-by”:[“cache-iah17283-IAH”],“x-timer”:[“S1610418102.249049,VS0,VE1”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Successfully connected to IPC server: etcher-server-11504, socket root C:\Users\danga\AppData\Local\Temp
gui.js:56886 Image: C:\Users\danga\OneDrive\Documents\2021-01-11_2020-12-02-octopi-buster-armhf-lite-0.18.0\2020-12-02-octopi-buster-armhf-lite-0.18.0.img
gui.js:56886 Devices: \.\PhysicalDrive1
gui.js:56886 Auto blockmapping: true
gui.js:56886 Decompress first: true
gui.js:6038 Flashing 1 device, 0% at 12.20 MB/s (total 12.20 MB/s) eta in 170s with 0 failed devices
gui.js:6038 Flashing 1 device, 1% at 12.30 MB/s (total 12.30 MB/s) eta in 168s with 0 failed devices
gui.js:6038 Flashing 1 device, 1% at 12.60 MB/s (total 12.60 MB/s) eta in 162s with 0 failed devices
gui.js:6038 Flashing 1 device, 2% at 13.10 MB/s (total 13.10 MB/s) eta in 155s with 0 failed devices
gui.js:6038 Flashing 1 device, 3% at 12.60 MB/s (total 12.60 MB/s) eta in 160s with 0 failed devices
gui.js:6038 Flashing 1 device, 3% at 12.10 MB/s (total 12.10 MB/s) eta in 166s with 0 failed devices
gui.js:6038 Flashing 1 device, 4% at 12.20 MB/s (total 12.20 MB/s) eta in 163s with 0 failed devices
gui.js:6038 Flashing 1 device, 4% at 12.80 MB/s (total 12.80 MB/s) eta in 155s with 0 failed devices
gui.js:6038 Flashing 1 device, 5% at 13.30 MB/s (total 13.30 MB/s) eta in 148s with 0 failed devices
gui.js:6038 Flashing 1 device, 6% at 12.30 MB/s (total 12.30 MB/s) eta in 159s with 0 failed devices
gui.js:6038 Flashing 1 device, 6% at 12.30 MB/s (total 12.30 MB/s) eta in 157s with 0 failed devices
gui.js:6038 Flashing 1 device, 7% at 12.80 MB/s (total 12.80 MB/s) eta in 151s with 0 failed devices
2gui.js:6038 Flashing 1 device, 8% at 12.70 MB/s (total 12.70 MB/s) eta in 150s with 0 failed devices
gui.js:6038 Flashing 1 device, 9% at 12.50 MB/s (total 12.50 MB/s) eta in 151s with 0 failed devices
gui.js:6038 Flashing 1 device, 9% at 12.80 MB/s (total 12.80 MB/s) eta in 147s with 0 failed devices
gui.js:6038 Flashing 1 device, 10% at 12.30 MB/s (total 12.30 MB/s) eta in 151s with 0 failed devices
gui.js:6038 Flashing 1 device, 11% at 12.10 MB/s (total 12.10 MB/s) eta in 153s with 0 failed devices
gui.js:6038 Flashing 1 device, 11% at 12.60 MB/s (total 12.60 MB/s) eta in 146s with 0 failed devices
gui.js:6038 Flashing 1 device, 12% at 12.80 MB/s (total 12.80 MB/s) eta in 143s with 0 failed devices
gui.js:6038 Flashing 1 device, 13% at 12.30 MB/s (total 12.30 MB/s) eta in 147s with 0 failed devices
gui.js:6038 Flashing 1 device, 13% at 12.20 MB/s (total 12.20 MB/s) eta in 148s with 0 failed devices
gui.js:6038 Flashing 1 device, 14% at 12.70 MB/s (total 12.70 MB/s) eta in 141s with 0 failed devices
gui.js:6038 Flashing 1 device, 14% at 12.80 MB/s (total 12.80 MB/s) eta in 139s with 0 failed devices
gui.js:6038 Flashing 1 device, 15% at 12.30 MB/s (total 12.30 MB/s) eta in 143s with 0 failed devices
gui.js:6038 Flashing 1 device, 16% at 12.30 MB/s (total 12.30 MB/s) eta in 142s with 0 failed devices
gui.js:6038 Flashing 1 device, 16% at 12.70 MB/s (total 12.70 MB/s) eta in 137s with 0 failed devices
gui.js:6038 Flashing 1 device, 17% at 12.80 MB/s (total 12.80 MB/s) eta in 134s with 0 failed devices
gui.js:6038 Flashing 1 device, 18% at 12.80 MB/s (total 12.80 MB/s) eta in 134s with 0 failed devices
gui.js:6038 Flashing 1 device, 18% at 12.50 MB/s (total 12.50 MB/s) eta in 135s with 0 failed devices
gui.js:6038 Flashing 1 device, 19% at 12.70 MB/s (total 12.70 MB/s) eta in 132s with 0 failed devices
gui.js:6038 Flashing 1 device, 19% at 13.40 MB/s (total 13.40 MB/s) eta in 124s with 0 failed devices
gui.js:6038 Flashing 1 device, 20% at 12.90 MB/s (total 12.90 MB/s) eta in 128s with 0 failed devices
gui.js:6038 Flashing 1 device, 21% at 12.90 MB/s (total 12.90 MB/s) eta in 128s with 0 failed devices
gui.js:6038 Flashing 1 device, 21% at 12.70 MB/s (total 12.70 MB/s) eta in 128s with 0 failed devices
gui.js:6038 Flashing 1 device, 22% at 12.70 MB/s (total 12.70 MB/s) eta in 127s with 0 failed devices
gui.js:6038 Flashing 1 device, 23% at 12.80 MB/s (total 12.80 MB/s) eta in 125s with 0 failed devices
gui.js:6038 Flashing 1 device, 23% at 12.30 MB/s (total 12.30 MB/s) eta in 130s with 0 failed devices
gui.js:6038 Flashing 1 device, 24% at 12.60 MB/s (total 12.60 MB/s) eta in 125s with 0 failed devices
gui.js:6038 Flashing 1 device, 24% at 12.60 MB/s (total 12.60 MB/s) eta in 124s with 0 failed devices
gui.js:6038 Flashing 1 device, 25% at 12.20 MB/s (total 12.20 MB/s) eta in 127s with 0 failed devices
gui.js:6038 Flashing 1 device, 26% at 12.40 MB/s (total 12.40 MB/s) eta in 124s with 0 failed devices
gui.js:6038 Flashing 1 device, 26% at 13.00 MB/s (total 13.00 MB/s) eta in 118s with 0 failed devices
gui.js:6038 Flashing 1 device, 27% at 12.70 MB/s (total 12.70 MB/s) eta in 119s with 0 failed devices
gui.js:6038 Flashing 1 device, 27% at 12.20 MB/s (total 12.20 MB/s) eta in 123s with 0 failed devices
gui.js:6038 Flashing 1 device, 28% at 12.80 MB/s (total 12.80 MB/s) eta in 116s with 0 failed devices
gui.js:6038 Flashing 1 device, 29% at 12.80 MB/s (total 12.80 MB/s) eta in 115s with 0 failed devices
gui.js:6038 Flashing 1 device, 29% at 12.30 MB/s (total 12.30 MB/s) eta in 119s with 0 failed devices
gui.js:6038 Flashing 1 device, 30% at 12.20 MB/s (total 12.20 MB/s) eta in 118s with 0 failed devices
gui.js:6038 Flashing 1 device, 31% at 12.90 MB/s (total 12.90 MB/s) eta in 111s with 0 failed devices
gui.js:6038 Flashing 1 device, 31% at 12.90 MB/s (total 12.90 MB/s) eta in 110s with 0 failed devices
gui.js:6038 Flashing 1 device, 32% at 12.20 MB/s (total 12.20 MB/s) eta in 115s with 0 failed devices
gui.js:6038 Flashing 1 device, 32% at 12.30 MB/s (total 12.30 MB/s) eta in 114s with 0 failed devices
gui.js:6038 Flashing 1 device, 33% at 12.70 MB/s (total 12.70 MB/s) eta in 109s with 0 failed devices
gui.js:6038 Flashing 1 device, 34% at 12.80 MB/s (total 12.80 MB/s) eta in 107s with 0 failed devices
gui.js:6038 Flashing 1 device, 34% at 12.40 MB/s (total 12.40 MB/s) eta in 109s with 0 failed devices
gui.js:6038 Flashing 1 device, 35% at 12.30 MB/s (total 12.30 MB/s) eta in 110s with 0 failed devices
gui.js:6038 Flashing 1 device, 36% at 12.80 MB/s (total 12.80 MB/s) eta in 104s with 0 failed devices
gui.js:6038 Flashing 1 device, 36% at 12.90 MB/s (total 12.90 MB/s) eta in 103s with 0 failed devices
gui.js:6038 Flashing 1 device, 37% at 12.30 MB/s (total 12.30 MB/s) eta in 107s with 0 failed devices
gui.js:6038 Flashing 1 device, 37% at 12.30 MB/s (total 12.30 MB/s) eta in 106s with 0 failed devices
gui.js:6038 Flashing 1 device, 38% at 12.90 MB/s (total 12.90 MB/s) eta in 99s with 0 failed devices
gui.js:6038 Flashing 1 device, 39% at 12.90 MB/s (total 12.90 MB/s) eta in 99s with 0 failed devices
gui.js:6038 Flashing 1 device, 39% at 12.30 MB/s (total 12.30 MB/s) eta in 102s with 0 failed devices
gui.js:6038 Flashing 1 device, 40% at 12.30 MB/s (total 12.30 MB/s) eta in 101s with 0 failed devices
gui.js:6038 Flashing 1 device, 40% at 12.80 MB/s (total 12.80 MB/s) eta in 96s with 0 failed devices
gui.js:6038 Flashing 1 device, 41% at 13.20 MB/s (total 13.20 MB/s) eta in 92s with 0 failed devices
gui.js:6038 Flashing 1 device, 42% at 12.70 MB/s (total 12.70 MB/s) eta in 95s with 0 failed devices
gui.js:6038 Flashing 1 device, 42% at 12.30 MB/s (total 12.30 MB/s) eta in 97s with 0 failed devices
gui.js:6038 Flashing 1 device, 43% at 12.40 MB/s (total 12.40 MB/s) eta in 95s with 0 failed devices
gui.js:6038 Flashing 1 device, 44% at 12.30 MB/s (total 12.30 MB/s) eta in 95s with 0 failed devices
gui.js:6038 Flashing 1 device, 44% at 12.20 MB/s (total 12.20 MB/s) eta in 94s with 0 failed devices
gui.js:6038 Flashing 1 device, 45% at 12.80 MB/s (total 12.80 MB/s) eta in 89s with 0 failed devices
gui.js:6038 Flashing 1 device, 45% at 12.80 MB/s (total 12.80 MB/s) eta in 88s with 0 failed devices
gui.js:6038 Flashing 1 device, 46% at 12.70 MB/s (total 12.70 MB/s) eta in 88s with 0 failed devices
gui.js:6038 Flashing 1 device, 47% at 12.50 MB/s (total 12.50 MB/s) eta in 88s with 0 failed devices
gui.js:6038 Flashing 1 device, 47% at 12.20 MB/s (total 12.20 MB/s) eta in 90s with 0 failed devices
gui.js:6038 Flashing 1 device, 48% at 12.90 MB/s (total 12.90 MB/s) eta in 83s with 0 failed devices
gui.js:6038 Flashing 1 device, 49% at 12.90 MB/s (total 12.90 MB/s) eta in 83s with 0 failed devices
gui.js:6038 Flashing 1 device, 49% at 12.20 MB/s (total 12.20 MB/s) eta in 86s with 0 failed devices
gui.js:6038 Flashing 1 device, 50% at 12.20 MB/s (total 12.20 MB/s) eta in 85s with 0 failed devices
gui.js:6038 Flashing 1 device, 50% at 12.70 MB/s (total 12.70 MB/s) eta in 80s with 0 failed devices
gui.js:6038 Flashing 1 device, 51% at 12.70 MB/s (total 12.70 MB/s) eta in 80s with 0 failed devices
gui.js:6038 Flashing 1 device, 52% at 12.20 MB/s (total 12.20 MB/s) eta in 82s with 0 failed devices
gui.js:6038 Flashing 1 device, 52% at 12.90 MB/s (total 12.90 MB/s) eta in 76s with 0 failed devices
gui.js:6038 Flashing 1 device, 53% at 12.90 MB/s (total 12.90 MB/s) eta in 75s with 0 failed devices
gui.js:6038 Flashing 1 device, 53% at 12.30 MB/s (total 12.30 MB/s) eta in 78s with 0 failed devices
gui.js:6038 Flashing 1 device, 54% at 12.20 MB/s (total 12.20 MB/s) eta in 78s with 0 failed devices
gui.js:6038 Flashing 1 device, 55% at 12.80 MB/s (total 12.80 MB/s) eta in 73s with 0 failed devices
gui.js:6038 Flashing 1 device, 55% at 12.90 MB/s (total 12.90 MB/s) eta in 71s with 0 failed devices
gui.js:6038 Flashing 1 device, 56% at 12.80 MB/s (total 12.80 MB/s) eta in 71s with 0 failed devices
gui.js:6038 Flashing 1 device, 57% at 12.80 MB/s (total 12.80 MB/s) eta in 70s with 0 failed devices
gui.js:6038 Flashing 1 device, 57% at 12.80 MB/s (total 12.80 MB/s) eta in 69s with 0 failed devices
gui.js:6038 Flashing 1 device, 58% at 12.80 MB/s (total 12.80 MB/s) eta in 68s with 0 failed devices
gui.js:6038 Flashing 1 device, 58% at 12.90 MB/s (total 12.90 MB/s) eta in 66s with 0 failed devices
gui.js:6038 Flashing 1 device, 59% at 12.40 MB/s (total 12.40 MB/s) eta in 68s with 0 failed devices
gui.js:6038 Flashing 1 device, 60% at 12.40 MB/s (total 12.40 MB/s) eta in 67s with 0 failed devices
gui.js:6038 Flashing 1 device, 60% at 12.80 MB/s (total 12.80 MB/s) eta in 64s with 0 failed devices
gui.js:6038 Flashing 1 device, 61% at 12.60 MB/s (total 12.60 MB/s) eta in 64s with 0 failed devices
gui.js:6038 Flashing 1 device, 62% at 12.50 MB/s (total 12.50 MB/s) eta in 63s with 0 failed devices
gui.js:6038 Flashing 1 device, 62% at 12.20 MB/s (total 12.20 MB/s) eta in 64s with 0 failed devices
gui.js:6038 Flashing 1 device, 63% at 12.70 MB/s (total 12.70 MB/s) eta in 60s with 0 failed devices
gui.js:6038 Flashing 1 device, 63% at 12.60 MB/s (total 12.60 MB/s) eta in 60s with 0 failed devices
gui.js:6038 Flashing 1 device, 64% at 12.30 MB/s (total 12.30 MB/s) eta in 60s with 0 failed devices
gui.js:6038 Flashing 1 device, 65% at 12.70 MB/s (total 12.70 MB/s) eta in 57s with 0 failed devices
gui.js:6038 Flashing 1 device, 65% at 13.10 MB/s (total 13.10 MB/s) eta in 54s with 0 failed devices
gui.js:6038 Flashing 1 device, 66% at 12.70 MB/s (total 12.70 MB/s) eta in 55s with 0 failed devices
gui.js:6038 Flashing 1 device, 67% at 12.70 MB/s (total 12.70 MB/s) eta in 54s with 0 failed devices
gui.js:6038 Flashing 1 device, 67% at 12.90 MB/s (total 12.90 MB/s) eta in 52s with 0 failed devices
gui.js:6038 Flashing 1 device, 68% at 12.60 MB/s (total 12.60 MB/s) eta in 52s with 0 failed devices
gui.js:6038 Flashing 1 device, 68% at 12.60 MB/s (total 12.60 MB/s) eta in 51s with 0 failed devices
gui.js:6038 Flashing 1 device, 69% at 12.90 MB/s (total 12.90 MB/s) eta in 49s with 0 failed devices
gui.js:6038 Flashing 1 device, 70% at 12.90 MB/s (total 12.90 MB/s) eta in 48s with 0 failed devices
gui.js:6038 Flashing 1 device, 70% at 12.80 MB/s (total 12.80 MB/s) eta in 47s with 0 failed devices
gui.js:6038 Flashing 1 device, 71% at 12.60 MB/s (total 12.60 MB/s) eta in 47s with 0 failed devices
gui.js:6038 Flashing 1 device, 72% at 12.60 MB/s (total 12.60 MB/s) eta in 46s with 0 failed devices
gui.js:6038 Flashing 1 device, 72% at 13.10 MB/s (total 13.10 MB/s) eta in 43s with 0 failed devices
gui.js:6038 Flashing 1 device, 73% at 13.20 MB/s (total 13.20 MB/s) eta in 42s with 0 failed devices
gui.js:6038 Flashing 1 device, 74% at 12.70 MB/s (total 12.70 MB/s) eta in 43s with 0 failed devices
gui.js:6038 Flashing 1 device, 74% at 12.70 MB/s (total 12.70 MB/s) eta in 41s with 0 failed devices
gui.js:6038 Flashing 1 device, 75% at 12.80 MB/s (total 12.80 MB/s) eta in 40s with 0 failed devices
gui.js:6038 Flashing 1 device, 75% at 12.80 MB/s (total 12.80 MB/s) eta in 39s with 0 failed devices
gui.js:6038 Flashing 1 device, 76% at 12.80 MB/s (total 12.80 MB/s) eta in 38s with 0 failed devices
gui.js:6038 Flashing 1 device, 77% at 12.70 MB/s (total 12.70 MB/s) eta in 37s with 0 failed devices
gui.js:6038 Flashing 1 device, 77% at 12.70 MB/s (total 12.70 MB/s) eta in 36s with 0 failed devices
gui.js:6038 Flashing 1 device, 78% at 12.40 MB/s (total 12.40 MB/s) eta in 36s with 0 failed devices
gui.js:6038 Flashing 1 device, 79% at 12.50 MB/s (total 12.50 MB/s) eta in 35s with 0 failed devices
gui.js:6038 Flashing 1 device, 79% at 12.90 MB/s (total 12.90 MB/s) eta in 33s with 0 failed devices
gui.js:6038 Flashing 1 device, 80% at 12.80 MB/s (total 12.80 MB/s) eta in 32s with 0 failed devices
gui.js:6038 Flashing 1 device, 81% at 12.70 MB/s (total 12.70 MB/s) eta in 31s with 0 failed devices
gui.js:6038 Flashing 1 device, 81% at 12.80 MB/s (total 12.80 MB/s) eta in 30s with 0 failed devices
gui.js:6038 Flashing 1 device, 82% at 12.80 MB/s (total 12.80 MB/s) eta in 29s with 0 failed devices
gui.js:6038 Flashing 1 device, 82% at 12.80 MB/s (total 12.80 MB/s) eta in 28s with 0 failed devices
gui.js:6038 Flashing 1 device, 83% at 12.60 MB/s (total 12.60 MB/s) eta in 27s with 0 failed devices
gui.js:6038 Flashing 1 device, 84% at 12.70 MB/s (total 12.70 MB/s) eta in 26s with 0 failed devices
gui.js:6038 Flashing 1 device, 84% at 12.80 MB/s (total 12.80 MB/s) eta in 25s with 0 failed devices
gui.js:6038 Flashing 1 device, 85% at 12.80 MB/s (total 12.80 MB/s) eta in 24s with 0 failed devices
gui.js:6038 Flashing 1 device, 85% at 12.70 MB/s (total 12.70 MB/s) eta in 23s with 0 failed devices
gui.js:6038 Flashing 1 device, 86% at 12.60 MB/s (total 12.60 MB/s) eta in 22s with 0 failed devices
gui.js:6038 Flashing 1 device, 87% at 12.50 MB/s (total 12.50 MB/s) eta in 21s with 0 failed devices
gui.js:6038 Flashing 1 device, 87% at 12.70 MB/s (total 12.70 MB/s) eta in 20s with 0 failed devices
gui.js:6038 Flashing 1 device, 88% at 12.40 MB/s (total 12.40 MB/s) eta in 20s with 0 failed devices
gui.js:6038 Flashing 1 device, 89% at 12.80 MB/s (total 12.80 MB/s) eta in 18s with 0 failed devices
gui.js:6038 Flashing 1 device, 89% at 13.20 MB/s (total 13.20 MB/s) eta in 16s with 0 failed devices
gui.js:6038 Flashing 1 device, 90% at 12.70 MB/s (total 12.70 MB/s) eta in 16s with 0 failed devices
gui.js:6038 Flashing 1 device, 90% at 12.20 MB/s (total 12.20 MB/s) eta in 16s with 0 failed devices
gui.js:6038 Flashing 1 device, 91% at 12.80 MB/s (total 12.80 MB/s) eta in 14s with 0 failed devices
gui.js:6038 Flashing 1 device, 92% at 13.40 MB/s (total 13.40 MB/s) eta in 12s with 0 failed devices
gui.js:6038 Flashing 1 device, 92% at 12.40 MB/s (total 12.40 MB/s) eta in 12s with 0 failed devices
gui.js:6038 Flashing 1 device, 93% at 12.40 MB/s (total 12.40 MB/s) eta in 11s with 0 failed devices
gui.js:6038 Flashing 1 device, 94% at 12.80 MB/s (total 12.80 MB/s) eta in 10s with 0 failed devices
gui.js:6038 Flashing 1 device, 94% at 12.50 MB/s (total 12.50 MB/s) eta in 9s with 0 failed devices
gui.js:6038 Flashing 1 device, 95% at 12.60 MB/s (total 12.60 MB/s) eta in 8s with 0 failed devices
gui.js:6038 Flashing 1 device, 95% at 12.80 MB/s (total 12.80 MB/s) eta in 7s with 0 failed devices
gui.js:6038 Flashing 1 device, 96% at 12.80 MB/s (total 12.80 MB/s) eta in 6s with 0 failed devices
gui.js:6038 Flashing 1 device, 97% at 12.60 MB/s (total 12.60 MB/s) eta in 5s with 0 failed devices
gui.js:6038 Flashing 1 device, 97% at 12.50 MB/s (total 12.50 MB/s) eta in 4s with 0 failed devices
gui.js:6038 Flashing 1 device, 98% at 12.50 MB/s (total 12.50 MB/s) eta in 3s with 0 failed devices
gui.js:6038 Flashing 1 device, 99% at 13.10 MB/s (total 13.10 MB/s) eta in 1s with 0 failed devices
gui.js:6038 Flashing 1 device, 100% at 12.80 MB/s (total 12.80 MB/s) eta in 0s with 0 failed devices
gui.js:6038 Verifying 1 device, 0% at 16.20 MB/s (total 16.20 MB/s) eta in 128s with 0 failed devices
gui.js:6038 Verifying 1 device, 1% at 15.90 MB/s (total 15.90 MB/s) eta in 129s with 0 failed devices
gui.js:6038 Verifying 1 device, 2% at 15.90 MB/s (total 15.90 MB/s) eta in 129s with 0 failed devices
gui.js:6038 Verifying 1 device, 3% at 17.30 MB/s (total 17.30 MB/s) eta in 117s with 0 failed devices
gui.js:6038 Verifying 1 device, 3% at 17.90 MB/s (total 17.90 MB/s) eta in 112s with 0 failed devices
gui.js:6038 Verifying 1 device, 4% at 17.40 MB/s (total 17.40 MB/s) eta in 114s with 0 failed devices
gui.js:6038 Verifying 1 device, 5% at 17.30 MB/s (total 17.30 MB/s) eta in 114s with 0 failed devices
gui.js:6038 Verifying 1 device, 6% at 17.30 MB/s (total 17.30 MB/s) eta in 113s with 0 failed devices
gui.js:6038 Verifying 1 device, 7% at 17.20 MB/s (total 17.20 MB/s) eta in 112s with 0 failed devices
gui.js:6038 Verifying 1 device, 8% at 17.60 MB/s (total 17.60 MB/s) eta in 109s with 0 failed devices
gui.js:6038 Verifying 1 device, 9% at 17.60 MB/s (total 17.60 MB/s) eta in 107s with 0 failed devices
gui.js:6038 Verifying 1 device, 10% at 17.80 MB/s (total 17.80 MB/s) eta in 106s with 0 failed devices
gui.js:6038 Verifying 1 device, 10% at 17.70 MB/s (total 17.70 MB/s) eta in 105s with 0 failed devices
gui.js:6038 Verifying 1 device, 11% at 17.50 MB/s (total 17.50 MB/s) eta in 105s with 0 failed devices
gui.js:6038 Verifying 1 device, 12% at 17.80 MB/s (total 17.80 MB/s) eta in 102s with 0 failed devices
gui.js:6038 Verifying 1 device, 13% at 17.30 MB/s (total 17.30 MB/s) eta in 104s with 0 failed devices
gui.js:6038 Verifying 1 device, 14% at 17.10 MB/s (total 17.10 MB/s) eta in 104s with 0 failed devices
gui.js:6038 Verifying 1 device, 15% at 17.20 MB/s (total 17.20 MB/s) eta in 103s with 0 failed devices
gui.js:56886 Mon Jan 11 2021 21:24:51 GMT-0500 (Eastern Standard Time) Validation error ({“image”:{“size”:2489319424,“name”:“2020-12-02-octopi-buster-armhf-lite-0.18.0.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:2216689664,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\danga\OneDrive\Documents\2021-01-11_2020-12-02-octopi-buster-armhf-lite-0.18.0\2020-12-02-octopi-buster-armhf-lite-0.18.0.img”},“drives”:[{“size”:62209916928,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“2d2cd3e6-f7be-49e0-8ab5-765cdb005da8”,“flashInstanceUuid”:“2d2cd3e6-f7be-49e0-8ab5-765cdb005da8”,“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:6038 Verifying 1 device, 16% at 17.20 MB/s (total 17.20 MB/s) eta in 101s with 0 failed devices
gui.js:56886 Finish: 334495744
gui.js:56886 Terminating IPC server
gui.js:56886 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:56886 Mon Jan 11 2021 21:24:55 GMT-0500 (Eastern Standard Time) Done ({“image”:{“size”:2489319424,“name”:“2020-12-02-octopi-buster-armhf-lite-0.18.0.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:2216689664,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\danga\OneDrive\Documents\2021-01-11_2020-12-02-octopi-buster-armhf-lite-0.18.0\2020-12-02-octopi-buster-armhf-lite-0.18.0.img”},“drives”:[{“size”:62209916928,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“2d2cd3e6-f7be-49e0-8ab5-765cdb005da8”,“status”:“finished”,“flashInstanceUuid”:“2d2cd3e6-f7be-49e0-8ab5-765cdb005da8”,“errors”:[{“name”:“Error”,“description”:“Mass Storage Device USB Device”,“code”:“EVALIDATION”,“device”:"\\.\PhysicalDrive1"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:334495744,“sourceMetadata”:{“size”:2489319424,“name”:“2020-12-02-octopi-buster-armhf-lite-0.18.0.img”,“blocks”:[{“blocks”:[{“offset”:0,“length”:335544320}]},{“blocks”:[{“offset”:406847488,“length”:1274019840}]},{“blocks”:[{“offset”:1681915904,“length”:104857600}]},{“blocks”:[{“offset”:1787822080,“length”:216006656}]},{“blocks”:[{“offset”:2004877312,“length”:3145728}]},{“blocks”:[{“offset”:2009071616,“length”:3145728}]},{“blocks”:[{“offset”:2013265920,“length”:104857600}]},{“blocks”:[{“offset”:2119172096,“length”:8388608}]},{“blocks”:[{“offset”:2128609280,“length”:1048576}]},{“blocks”:[{“offset”:2130706432,“length”:3145728}]},{“blocks”:[{“offset”:2134900736,“length”:3145728}]},{“blocks”:[{“offset”:2139095040,“length”:2097152}]},{“blocks”:[{“offset”:2143289344,“length”:16777216}]},{“blocks”:[{“offset”:2269118464,“length”:4194304}]},{“blocks”:[{“offset”:2420113408,“length”:3145728}]}],“blockmappedSize”:2083520512},“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Mon Jan 11 2021 21:24:55 GMT-0500 (Eastern Standard Time) SafeWebview loaded ({“event”:{“id”:20,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.5.113&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1610418295404.122,“resourceType”:“mainFrame”,“ip”:“157.245.130.6”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“256540”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6304”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Sat, 09 Jan 2021 03:09:15 GMT”],“etag”:["“970b74742e7532ee6b9cae0df7cbb3e4-ssl-df”"],“link”:["</webpack-runtime-ce1cdff5f5359785d844.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-5caee277c7b8d7ec6fc1.js>; rel=preload; as=script, </73ad3401-b34093a8033d990846f8.js>; rel=preload; as=script, </532a2f07-79d7d47f8c4538117bc1.js>; rel=preload; as=script, </app-a63e98fe07b83b4dcbb9.js>; rel=preload; as=script, </c943faba-8401ef931f889cf944b7.js>; rel=preload; as=script, </af13d906-dfae2e0b903ca182e45d.js>; rel=preload; as=script, </ec1189df-f1a321eba12a2bb0c7ab.js>; rel=preload; as=script, </a9a7754c-8c1c986c04a5e7e0eb7d.js>; rel=preload; as=script, </4cb05eeb-219a14f8e992900324ba.js>; rel=preload; as=script, </231dbb27-15b3b2f75c4c43dc9f06.js>; rel=preload; as=script, </09701b4e-602dc43e99c6afa2c703.js>; rel=preload; as=script, </8adc965a-b9abcbb4111e331348c8.js>; rel=preload; as=script, </42cf64af-f20bd93ce07ef388a461.js>; rel=preload; as=script, </commons-6ca2a9db64973fe46f5f.js>; rel=preload; as=script, </12a4e5f96801425b4fc2bcf8098f301f029556a5-3c068fd00d5480658814.js>; rel=preload; as=script, </1f9101bfa6ab6b5c77f1b7191fb4987950aee8e9-2a13ff60a3f77104df6a.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-acad0c3506d4c602db49.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“same-origin”],“server”:[“Netlify”],“status”:[“200”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“09bff1a9-2593-4201-a033-ad4c2c38f128-25151499”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
gui.js:56886 Mon Jan 11 2021 21:38:13 GMT-0500 (Eastern Standard Time) Restart ({“sample”:0.1,“applicationSessionUuid”:“a50c440b-4340-46a8-a27a-3a5c27dda6e4”,“flashingWorkflowUuid”:“a04e1af5-6180-4bfc-b977-386796d57f99”})
similar issue. I have version 1.5.116 and it flashes, completes the format and the drive mount but it looks to me like its not creating a large enough partition? Maybe it fails copying the image?
  1. I am running program as administrator
  2. The drive is 32G buts only formatting the E: drive as 16MB (the image to copy is 85MB)
  3. everything seems to work but when its done it says “flash failed”
  4. When its done the drive isnt usually mounted but if I reinsert there is a drive with data on it totaling about 15MB.
gui.js:42737 Sun Apr 25 2021 19:00:57 GMT-0400 (Eastern Daylight Time) Flash error ({“image”:{“size”:84934656,“name”:“braiins-os_am1-s9_sd-install_2021-02-23-0-17eb8395-21.02.1-plus.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:16777216,“type”:12,“index”:1},{“offset”:17825792,“size”:67108864,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\temp\miner\braiin\sdcard\braiins-os_am1-s9_sd-install_2021-02-23-0-17eb8395-21.02.1-plus.img”},“drives”:[{“size”:31016878080,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“Generic- SD/MMC USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“2693125c-b4c5-47ea-bd48-36d1bc7ca644”,“flashInstanceUuid”:“2693125c-b4c5-47ea-bd48-36d1bc7ca644”,“error”:{“name”:“Error”,“message”:“Unmount failed”,“stack”:“Error: Unmount failed”},“sample”:0.1,“applicationSessionUuid”:“e57ff5e0-1aa0-4bcb-9418-efd82630d1d7”,“flashingWorkflowUuid”:“05d4faae-9cba-4b25-b7fc-c6be895d88d1”})
gui.js:42737 Finish: 40894464
gui.js:42737 Terminating IPC server
gui.js:42737 Flash results
  1. {results: {…}, cancelled: false, skip: false}
gui.js:42737 Sun Apr 25 2021 19:00:57 GMT-0400 (Eastern Daylight Time) Done ({“image”:{“size”:84934656,“name”:“braiins-os_am1-s9_sd-install_2021-02-23-0-17eb8395-21.02.1-plus.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:16777216,“type”:12,“index”:1},{“offset”:17825792,“size”:67108864,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\temp\miner\braiin\sdcard\braiins-os_am1-s9_sd-install_2021-02-23-0-17eb8395-21.02.1-plus.img”},“drives”:[{“size”:31016878080,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“Generic- SD/MMC USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“2693125c-b4c5-47ea-bd48-36d1bc7ca644”,“status”:“finished”,“flashInstanceUuid”:“2693125c-b4c5-47ea-bd48-36d1bc7ca644”,“errors”:[{“name”:“Error”,“description”:“Generic- SD/MMC USB Device”,“device”:"\\.\PhysicalDrive2"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:40894464,“sourceMetadata”:{“size”:84934656,“name”:“braiins-os_am1-s9_sd-install_2021-02-23-0-17eb8395-21.02.1-plus.img”,“blocks”:[{“blocks”:[{“offset”:0,“length”:53477376}]},{“blocks”:[{“offset”:59768832,“length”:1048576}]},{“blocks”:[{“offset”:76546048,“length”:1048576}]}],“blockmappedSize”:55574528},“sample”:0.1,“applicationSessionUuid”:“e57ff5e0-1aa0-4bcb-9418-efd82630d1d7”,“flashingWorkflowUuid”:“05d4faae-9cba-4b25-b7fc-c6be895d88d1”})
gui.js:42737 Sun Apr 25 2021 19:00:58 GMT-0400 (Eastern Daylight Time) SafeWebview loaded ({“event”:{“id”:21,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.5.116&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1619391658456.192,“resourceType”:“mainFrame”,“ip”:“52.73.87.228”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“4657”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6048”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Sun, 25 Apr 2021 21:40:17 GMT”],“etag”:["“91d9082cd6df11651392eb5efd79f28f-ssl-df”"],“link”:["</webpack-runtime-f80771560d195847408d.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-42f2600cafd3c0e08aac.js>; rel=preload; as=script, </50c25a04-efe577ee14c9c53bed03.js>; rel=preload; as=script, </73ad3401-e112b47ad7a992b91ac8.js>; rel=preload; as=script, </532a2f07-16f3498dd087ee7288d4.js>; rel=preload; as=script, </app-bf00336f401e3107e78c.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-f1a321eba12a2bb0c7ab.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-f107fce4e0358d11a866.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-b3df158ccec49c4b44f3.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“status”:[“200”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“289d4cc9-3147-4f46-b000-0c4eda1c2bbe-37938919”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“e57ff5e0-1aa0-4bcb-9418-efd82630d1d7”,“flashingWorkflowUuid”:“05d4faae-9cba-4b25-b7fc-c6be895d88d1”})
gui.js:42737 Sun Apr 25 2021 19:08:09 GMT-0400 (Eastern Daylight Time) Open external link ({“url”:“https://github.com/balena-io/etcher/blob/master/SUPPORT.md",“sample”:0.1,“applicationSessionUuid”:“e57ff5e0-1aa0-4bcb-9418-efd82630d1d7”,“flashingWorkflowUuid”:"05d4faae-9cba-4b25-b7fc-c6be895d88d1”})
it says flash failed. It also unmounts it. when i open the usb it says efi pls help my pc is dead
Hello
I have been continually getting “flash failed” and I’m not sure what I’m doing wrong.
I have tried on two different computers, same result.
Any advice would be appreciated.
Hi Shaun, what are you attempting to flash? What image file are you flashing, and, what platform are you currently running on? Windows? Mac?
Also, even though it does say flash failed, can you try booting whatever it is that you flashed? Just curious if it actually works, even though we are indicating the error message. Thanks!
I gave up, it didn’t work.
@dajohnso Sorry to hear that it didn’t work. Can you help us with a bit more details on what you tried? Is the boot up not working?
Any details on the environment you ran this in and which particular image failed, and/or errors from the console (developer console) can help us provide you with corrective steps here.
Regards,
N
same error everyone else says. I was trying to load an image for BraiinOS from my Windows PC. I gave up on this app and ended up using something else. Every complaint on this site was answered with what version, what are you trying to copy and no suggestion on how to fix it even though several posts had very detailed log files (i.e. including mine). I moved on to another product and had no issues at all. I reviewed all available logs and there was no reason given for the failure.
I got the same error when using kali linux 2021.3a, my log says “Unmount failed”. Any idea, what could be the problem??
  1. cancelled: false
  2. results:
  3. averageFlashingSpeed: 5472020.874103066
  4. bytesWritten: 8388608
  5. devices:
    1. failed: 1
    2. successful: 0
    3. proto: Object
  6. errors: Array(1)
    1. 0: Error: Unmount failed
    1. description: “ADATA USB Flash Drive USB Device”
    2. device: “\.\PhysicalDrive2”
    3. name: “Error”
    4. message: “Unmount failed”
    5. stack: “Error: Unmount failed”
    6. proto: Object
2. length: 1
3. __proto__: Array(0)
  1. sourceMetadata: {size: 4028575744, name: “kali-linux-2021.3a-live-amd64.iso”, blocks: Array(1), blockmappedSize: 4028575744}
  2. proto: Object
  3. skip: false
  4. proto: Object
Similar verification failure when flashing ChromiumOS… Please advise:
Verifying 1 device, 65% at 15.20 MB/s (total 15.20 MB/s) eta in 52s with 0 failed devices
gui.js:51697 Sun Nov 14 2021 07:52:22 GMT+0530 (India Standard Time) Validation error ({“image”:{“size”:6606109184,“name”:“chromiumos_image.bin”,“hasMBR”:true,“partitions”:[{“offset”:2311061504,“size”:4295023104,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“182BE636-6686-6642-AAF6-489E1B86B362”,“name”:“STATE”,“index”:1},{“offset”:10485760,“size”:16777216,“type”:“FE3A2A5D-4F32-41A7-B725-ACCC3285A309”,“guid”:“7C7BC1D3-80E1-2D48-9F0D-DA7A4F0CBABD”,“name”:“KERN-A”,“index”:2},{“offset”:163577856,“size”:2147483648,“type”:“3CB8E202-3B7E-47DD-8A3C-7FF2A13CFCEC”,“guid”:“CA5CC5EF-DF57-E647-ADCB-362BEE08B3EA”,“name”:“ROOT-A”,“index”:3},{“offset”:27262976,“size”:16777216,“type”:“FE3A2A5D-4F32-41A7-B725-ACCC3285A309”,“guid”:“CC63BDD3-BF89-F84F-B6C5-767E7D484512”,“name”:“KERN-B”,“index”:4},{“offset”:161480704,“size”:2097152,“type”:“3CB8E202-3B7E-47DD-8A3C-7FF2A13CFCEC”,“guid”:“C74C0ADC-199F-CF4E-B0F3-0FE4716A5AB8”,“name”:“ROOT-B”,“index”:5},{“offset”:8421376,“size”:512,“type”:“FE3A2A5D-4F32-41A7-B725-ACCC3285A309”,“guid”:“840A2447-EB8B-7747-AE14-A2BDA66EE5AE”,“name”:“KERN-C”,“index”:6},{“offset”:8421888,“size”:512,“type”:“3CB8E202-3B7E-47DD-8A3C-7FF2A13CFCEC”,“guid”:“9257BD39-AB40-6B45-B6B5-8E6FB4F9FF2B”,“name”:“ROOT-C”,“index”:7},{“offset”:44040192,“size”:16777216,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“DCB74990-B01A-404D-9832-5BB93D5702A2”,“name”:“OEM”,“index”:8},{“offset”:8422400,“size”:512,“type”:“2E0A753D-9E48-43B0-8337-B15192CB1B5E”,“guid”:“2D0B17D6-2938-3840-BF16-70419DD30F9E”,“name”:“reserved”,“index”:9},{“offset”:8422912,“size”:512,“type”:“2E0A753D-9E48-43B0-8337-B15192CB1B5E”,“guid”:“413D5AFF-9739-4848-B91F-8B3735AB56F6”,“name”:“reserved”,“index”:10},{“offset”:32768,“size”:8388608,“type”:“CAB6E88E-ABF3-4102-A07A-D4BB9BE3C1D3”,“guid”:“341B2654-9C68-C943-96D6-D3DFAC69994D”,“name”:“RWFW”,“index”:11},{“offset”:127926272,“size”:33554432,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“B9B95BA3-BAA6-D44A-ACA3-9BCFB48011E2”,“name”:“EFI-SYSTEM”,“index”:12}],“extension”:“bin”,“path”:“D:\myDocs\Downloads\CARMOS-20211110231152.img\chromiumos_image.bin”},“drives”:[{“size”:8178892800,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:"E:\, , , , , , , , , , "}],“description”:“SMI USB DISK USB Device”,“isUAS”:false,“partitionTableType”:“gpt”}],“driveCount”:1,“uuid”:“136b5165-f2d2-4970-a4ef-9aee22c39613”,“flashInstanceUuid”:“136b5165-f2d2-4970-a4ef-9aee22c39613”,“sample”:0.1,“applicationSessionUuid”:“561aa9b1-5457-452f-ab7a-dc5a856049ce”,“flashingWorkflowUuid”:“3719e96d-3ed6-4360-ae3d-63ed5be3a41c”})
gui.js:39260 Verifying 1 device, 66% at 15.20 MB/s (total 15.20 MB/s) eta in 51s with 0 failed devices
gui.js:51697 Finish: 1515192320
gui.js:51697 Terminating IPC server
gui.js:51697 Flash results
gui.js:51697 Sun Nov 14 2021 07:52:27 GMT+0530 (India Standard Time) Done ({“image”:{“size”:6606109184,“name”:“chromiumos_image.bin”,“hasMBR”:true,“partitions”:[{“offset”:2311061504,“size”:4295023104,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“182BE636-6686-6642-AAF6-489E1B86B362”,“name”:“STATE”,“index”:1},{“offset”:10485760,“size”:16777216,“type”:“FE3A2A5D-4F32-41A7-B725-ACCC3285A309”,“guid”:“7C7BC1D3-80E1-2D48-9F0D-DA7A4F0CBABD”,“name”:“KERN-A”,“index”:2},{“offset”:163577856,“size”:2147483648,“type”:“3CB8E202-3B7E-47DD-8A3C-7FF2A13CFCEC”,“guid”:“CA5CC5EF-DF57-E647-ADCB-362BEE08B3EA”,“name”:“ROOT-A”,“index”:3},{“offset”:27262976,“size”:16777216,“type”:“FE3A2A5D-4F32-41A7-B725-ACCC3285A309”,“guid”:“CC63BDD3-BF89-F84F-B6C5-767E7D484512”,“name”:“KERN-B”,“index”:4},{“offset”:161480704,“size”:2097152,“type”:“3CB8E202-3B7E-47DD-8A3C-7FF2A13CFCEC”,“guid”:“C74C0ADC-199F-CF4E-B0F3-0FE4716A5AB8”,“name”:“ROOT-B”,“index”:5},{“offset”:8421376,“size”:512,“type”:“FE3A2A5D-4F32-41A7-B725-ACCC3285A309”,“guid”:“840A2447-EB8B-7747-AE14-A2BDA66EE5AE”,“name”:“KERN-C”,“index”:6},{“offset”:8421888,“size”:512,“type”:“3CB8E202-3B7E-47DD-8A3C-7FF2A13CFCEC”,“guid”:“9257BD39-AB40-6B45-B6B5-8E6FB4F9FF2B”,“name”:“ROOT-C”,“index”:7},{“offset”:44040192,“size”:16777216,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“DCB74990-B01A-404D-9832-5BB93D5702A2”,“name”:“OEM”,“index”:8},{“offset”:8422400,“size”:512,“type”:“2E0A753D-9E48-43B0-8337-B15192CB1B5E”,“guid”:“2D0B17D6-2938-3840-BF16-70419DD30F9E”,“name”:“reserved”,“index”:9},{“offset”:8422912,“size”:512,“type”:“2E0A753D-9E48-43B0-8337-B15192CB1B5E”,“guid”:“413D5AFF-9739-4848-B91F-8B3735AB56F6”,“name”:“reserved”,“index”:10},{“offset”:32768,“size”:8388608,“type”:“CAB6E88E-ABF3-4102-A07A-D4BB9BE3C1D3”,“guid”:“341B2654-9C68-C943-96D6-D3DFAC69994D”,“name”:“RWFW”,“index”:11},{“offset”:127926272,“size”:33554432,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“B9B95BA3-BAA6-D44A-ACA3-9BCFB48011E2”,“name”:“EFI-SYSTEM”,“index”:12}],“extension”:“bin”,“path”:“D:\myDocs\Downloads\CARMOS-20211110231152.img\chromiumos_image.bin”},“drives”:[{“size”:8178892800,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“E:\, , , , , , , , , , “}],“description”:“SMI USB DISK USB Device”,“isUAS”:false,“partitionTableType”:“gpt”}],“driveCount”:1,“uuid”:“136b5165-f2d2-4970-a4ef-9aee22c39613”,“status”:“finished”,“flashInstanceUuid”:“136b5165-f2d2-4970-a4ef-9aee22c39613”,“errors”:[{“name”:“Error”,“description”:“SMI USB DISK USB Device”,“code”:“EVALIDATION”,“device”:”\\.\PhysicalDrive2”}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:1515192320,“sourceMetadata”:{“size”:6606109184,“name”:“chromiumos_image.bin”,“blocks”:[{“blocks”:[{“offset”:0,“length”:50331648}]},{“blocks”:[{“offset”:60817408,“length”:105906176}]},{“blocks”:[{“offset”:297795584,“length”:3145728}]},{“blocks”:[{“offset”:432013312,“length”:2097152}]},{“blocks”:[{“offset”:566231040,“length”:3145728}]},{“blocks”:[{“offset”:700448768,“length”:7340032}]},{“blocks”:[{“offset”:708837376,“length”:687865856}]},{“blocks”:[{“offset”:1398800384,“length”:2097152}]},{“blocks”:[{“offset”:1402994688,“length”:76546048}]},{“blocks”:[{“offset”:1480589312,“length”:70254592}]},{“blocks”:[{“offset”:1551892480,“length”:3145728}]},{“blocks”:[{“offset”:1556086784,“length”:1048576}]},{“blocks”:[{“offset”:1558183936,“length”:17825792}]},{“blocks”:[{“offset”:1577058304,“length”:7340032}]},{“blocks”:[{“offset”:1585446912,“length”:11534336}]},{“blocks”:[{“offset”:1598029824,“length”:78643200}]},{“blocks”:[{“offset”:1677721600,“length”:3145728}]},{“blocks”:[{“offset”:1681915904,“length”:5242880}]},{“blocks”:[{“offset”:1688207360,“length”:1048576}]},{“blocks”:[{“offset”:1690304512,“length”:173015040}]},{“blocks”:[{“offset”:1864368128,“length”:6291456}]},{“blocks”:[{“offset”:1874853888,“length”:47185920}]},{“blocks”:[{“offset”:1923088384,“length”:1048576}]},{“blocks”:[{“offset”:1925185536,“length”:52428800}]},{“blocks”:[{“offset”:2042626048,“length”:2097152}]},{“blocks”:[{“offset”:2176843776,“length”:3145728}]},{“blocks”:[{“offset”:2181038080,“length”:1048576}]},{“blocks”:[{“offset”:2183135232,“length”:1048576}]},{“blocks”:[{“offset”:2185232384,“length”:1048576}]},{“blocks”:[{“offset”:2187329536,“length”:2097152}]},{“blocks”:[{“offset”:2191523840,“length”:1048576}]},{“blocks”:[{“offset”:2193620992,“length”:1048576}]},{“blocks”:[{“offset”:2260729856,“length”:89128960}]},{“blocks”:[{“offset”:2445279232,“length”:134217728}]},{“blocks”:[{“offset”:2581594112,“length”:1048576}]},{“blocks”:[{“offset”:2713714688,“length”:7340032}]},{“blocks”:[{“offset”:2722103296,“length”:119537664}]},{“blocks”:[{“offset”:2847932416,“length”:8388608}]},{“blocks”:[{“offset”:2982150144,“length”:3145728}]},{“blocks”:[{“offset”:3250585600,“length”:3145728}]},{“blocks”:[{“offset”:3519021056,“length”:3145728}]},{“blocks”:[{“offset”:4324327424,“length”:67108864}]},{“blocks”:[{“offset”:4458545152,“length”:39845888}]},{“blocks”:[{“offset”:4592762880,“length”:108003328}]},{“blocks”:[{“offset”:4701814784,“length”:1048576}]},{“blocks”:[{“offset”:4703911936,“length”:1048576}]},{“blocks”:[{“offset”:4706009088,“length”:1048576}]},{“blocks”:[{“offset”:4708106240,“length”:1048576}]},{“blocks”:[{“offset”:4710203392,“length”:1048576}]},{“blocks”:[{“offset”:4712300544,“length”:1048576}]},{“blocks”:[{“offset”:4714397696,“length”:1048576}]},{“blocks”:[{“offset”:4716494848,“length”:1048576}]},{“blocks”:[{“offset”:4718592000,“length”:1048576}]},{“blocks”:[{“offset”:4720689152,“length”:1048576}]},{“blocks”:[{“offset”:4722786304,“length”:1048576}]},{“blocks”:[{“offset”:4724883456,“length”:1048576}]},{“blocks”:[{“offset”:4861198336,“length”:1048576}]},{“blocks”:[{“offset”:4863295488,“length”:1048576}]},{“blocks”:[{“offset”:4865392640,“length”:1048576}]},{“blocks”:[{“offset”:4867489792,“length”:249561088}]},{“blocks”:[{“offset”:5129633792,“length”:6291456}]},{“blocks”:[{“offset”:5666504704,“length”:3145728}]},{“blocks”:[{“offset”:5934940160,“length”:3145728}]},{“blocks”:[{“offset”:6606028800,“length”:80384}]}],“blockmappedSize”:2292267520},“sample”:0.1,“applicationSessionUuid”:“561aa9b1-5457-452f-ab7a-dc5a856049ce”,“flashingWorkflowUuid”:“3719e96d-3ed6-4360-ae3d-63ed5be3a41c”})
gui.js:51697 Sun Nov 14 2021 07:52:27 GMT+0530 (India Standard Time) SafeWebview loaded ({“event”:{“id”:3,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.7.0&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1636856547793.53,“resourceType”:“mainFrame”,“ip”:“178.128.124.245”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“496475”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6205”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Mon, 08 Nov 2021 08:27:52 GMT”],“etag”:["“cbabb686515e0c8e845f85c6d57d7e1b-ssl-df”"],“link”:["</webpack-runtime-abc6ce91596caab5970e.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-7a8cbea6f167095a420c.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-a12561aebb4c48595dd6.js>; rel=preload; as=script, </c974efff6ac245e04f4a26711b42db767846e0e5-b1b7091203b51af325ff.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-98ac1a1084e1d2a478fa.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“01FME41HQ1FSK608KXR3GYR1JW”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“561aa9b1-5457-452f-ab7a-dc5a856049ce”,“flashingWorkflowUuid”:“3719e96d-3ed6-4360-ae3d-63ed5be3a41c”})
I am having the same issue here. Can anyone help me fix flashing Ubuntu using etcher failed to my micro SD card 128GB for RPi 4B+?
I was getting the same problem and it kept “bricking” (it’s not really bricking it but it was somehow breaking my USB stick) my flash drive.
If it does “brick” your flash drive - I found this and it helped recovering it: Etcher broke my USB stick … or did it?
I fixed my problem by simply letting it through windows firewall. Windows Defender was blocking it every time I tried flashing my USB stick
I tried with win32diskimager it works and after when I came back to balenaEtcher the problem disappeared
I’m flashing Ubuntu using balenaEtcher on my laptop(Lenovo Y9000X Windows x64), I’ve used Sandisk(64GB) and another unknown-brand (8GB) USB Flash Disk, but I’ve only got the message “User did not grant permission”
Could you please help me whats going wrong?
Thank you so much!
I just ran the app as an admin and it worked for me.
