Flash failed need help
I don’t see anything wrong.
Is that where it stops working? at 14%, it says flash failedand nothing happens afterwards?
You mentioned that after that, you opened the SD File System in Windows, and only so the boot partition. Actually windows does not recognize all types of partitions, so, if you don’t see them there it doesn’t mean they don’t exist.
Have you tried the SD card in your end-device?
