… means that the balena is trying to package your source folder and the resulting file is bigger than 2.147GB (roughly). Can you please check what’s the size of your source folder? Thanks.
I just ran the push command with the debug=1 option, it gives just a bit more info:
xxx:~/Raspberry$ DEBUG=1 balena push WebFramePiZeroW
[debug] Using . as build source
/ Packaging the project source…RangeError: File size is greater than possible Buffer: 0x7fffffff bytes
at FSReqWrap.readFileAfterStat [as oncomplete] (fs.js:453:11)
As for the steps I tried are the ones on the balena website:
I took another Linux machine and followed all the steps on the balena page to build the webframe. This time I had a bit more success, but aren’t there yet.
I got to push the app via the CLI and got the unicorn on my PC scree, the filesize matches what is shown your website.
However, the app is not deployed to my pi + screen. The pi+screen appears as online on my dashboard, so far so good. But the pi screen just shows “balena os, Booted check your balenacloud dashboard”.
So, I’m at a total loss here. Can you give some hints?
For the file size: It looks like you are trying to push all of your ~/Raspberry directory rather than just the source to the project. Push takes the remote application name as the argument.
For the second problem: Is the Pi joined to the right application?
