I encountered the problem while building an image containing CUDA, TF, OpenCV with the Nvidia Jetson Nano. Since i can not reopen the GitHub issue i mention it here.
[Debug] Parsing input...
[Debug] Loading project...
[Debug] Resolving project...
[Debug] docker-compose.yml file found at "/builds/.../..."
[Debug] Creating project...
[Info] Building for aarch64/jetson-nano
[Build] Building services...
[Build] jetson-nano-base Preparing...
[Info] Installing qemu for aarch64 emulation...
[Info] Emulation is enabled
[Build] Built 1 service in 0:01
[Error] Build failed
ERR_FS_FILE_TOO_LARGE: File size (2380747015) is greater than possible Buffer: 2147483647 bytes
RangeError [ERR_FS_FILE_TOO_LARGE]: File size (2380747015) is greater than possible Buffer: 2147483647 bytes
at FSReqWrap.readFileAfterStat [as oncomplete] (fs.js:264:11)
From previous event:
at readFile (eval at thenify.withCallback (/snapshot/versioned-source/node_modules/thenify/index.js:33:10), <anonymous>:10:8)
at /snapshot/versioned-source/build/utils/compose.js:156:49
at tarDirectory (/snapshot/versioned-source/build/utils/compose.js:153:28)
at /snapshot/versioned-source/build/utils/compose.js:216:12
at Object.exports.buildProject (/snapshot/versioned-source/build/utils/compose.js:215:6)
at /snapshot/versioned-source/build/actions/build.js:51:20
at buildProject (/snapshot/versioned-source/build/actions/build.js:45:60)
at /snapshot/versioned-source/build/actions/build.js:133:16
at /snapshot/versioned-source/build/actions/build.js:132:22
at Command.action (/snapshot/versioned-source/build/actions/build.js:129:8)
at /snapshot/versioned-source/node_modules/capitano/build/command.js:98:37
at Command.module.exports.Command.applyPermissions (/snapshot/versioned-source/node_modules/capitano/build/command.js:43:14)
at /snapshot/versioned-source/node_modules/capitano/build/command.js:92:24
at Command.module.exports.Command._checkElevation (/snapshot/versioned-source/node_modules/capitano/build/command.js:63:14)
at /snapshot/versioned-source/node_modules/capitano/build/command.js:76:22
at /snapshot/versioned-source/node_modules/capitano/build/signature.js:177:14
at _toString (/snapshot/versioned-source/node_modules/capitano/node_modules/async/lib/async.js:52:16)
at /snapshot/versioned-source/node_modules/capitano/node_modules/async/lib/async.js:269:32
at /snapshot/versioned-source/node_modules/capitano/node_modules/async/lib/async.js:44:16
at /snapshot/versioned-source/node_modules/capitano/build/signature.js:171:16
at _setImmediate (/snapshot/versioned-source/node_modules/capitano/node_modules/async/lib/async.js:181:20)
at Immediate.iterate (/snapshot/versioned-source/node_modules/capitano/node_modules/async/lib/async.js:262:13)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
It works on balena CLI V. 11.24.0 but does not work with v11.26.0 or v11.28.11 on Linux
