Hi all,
I’m brand new to Balena so trying to have a play with the services and came across the below blog which sounded like it could fulfill a project need quite nicely - https://www.balena.io/blog/deploy-free-digital-signage-software-screenly-ose/
However when trying to push the Screenly ISO obtained from Github (https://github.com/Screenly/screenly-ose/releases) I get the following error message:
File size is greater than possible Buffer: 0x7fffffff bytes
variable: “set DEBUG=1” on a Windows command prompt, or “export DEBUG=1”
on Linux or macOS.
If you need help, don’t hesitate in contacting our support forums at
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
The ISO file size is - 2.17GB, so is that past the size limit allowed for uploads or am I doing something completely wrong? As mentioned I’m pretty fresh with this stuff so when it says setting a DEBUG=1 environment, I’m not exactly sure how to do that, so if someone could point me in the direction of how to do that as well that would be great.
I am going to try and git push the file locally tonight if i get chance and see if my fortune improves but I figured it would be good to find out why this isn’t working as it makes no reference of it being an issue in the blog.
Cheers,
Jason.
I was using the Balena CLI in Powershell on a Windows10 machine with a Rasp Pi 3B+ device.
