llevo todo el dia intentando descargar balenaetcher para montar una retroarcade para mi hijo.
en estos dias de confinamiento. pero a la hora de instalarlo, solo llega al 40% y me dice instalacion abortada. alguien puede decirme que ocurre?
muy frustrado, espero puedan ilustrarme.
gracias.
Hello @181cp,
I have a couple of questions that would help us understand what the issue might be:
- What OS are you trying to install Etcher on?
- Did you download the latest version of Etcher?
- What is the error you are getting when the installation fails?
- Can you make sure you have enough disk space?
Cheers,
Nico
buenos dias nico.
gracias antes que nada por tu respuesta tan rapida.
el equipo desd eel que intento montar un pendrive con batocera gracias al balena etcher es un lenovo ideapad330.
i5 con windows 10. espacio mas que de sobra.130g.
https://www.balena.io/etcher/ descargue siempre desde aqui.
como antivirus solo tengo windows defender.
espero que pueda echarme una mano.
gracias.
Hi
Can you share additional logs?
On Windows, press ctrl+shift+i, it will open a window called Developer Tools - select the console tab. Then start your flashing process, and you will see logs on the console window of the Developer Tools. Please share those here
Hello, thank you for your reply, but we will need the logs from Etcher actually, not your browser. So, while Etcher is flashing that image, Control-Shift-I should open Developer Tools for Etcher. If you could copy / paste the Console output from that, it may help us to pinpoint the error. Also, it may be worth turning off Windows Defender, as I have seen that interfere on rare occasions, thanks.
