Failed balena-etcher_2.1.9_amd64.deb Install on Kubuntu 26.04 LTS
It appears that the “Access to ‘/opt/balena-etcher-electron/chrome-sandbox’ not possible: File or folder not found” failure is not yet fixed. I searched, and found “failed deb install on LMDE4” from Jun 2021, and read all the posts there, but there doesn’t apear to be a posted resolution. Not realizing that there was an issue, I ran the program, and was able to set the source .iso file, but could go no further. When i tried to run it again, the window opened, but was no longer populated with anything. I also tried to uninstall the app with sudo apt remove, but it couldn’t find the app.
My system is:
Operating System: Kubuntu 26.04 LTS
KDE Plasma Version: 6.6.6
KDE Frameworks Version: 6.24.0
Qt Version: 6.10.2
Kernel Version: 7.0.0-43-generic (64-bit)
Graphics Platform: Wayland
Processors: 8 × AMD FX™-9370 Eight-Core Processor
Memory: 32 GiB of RAM (31.2 GiB usable)
Graphics Processor: NVIDIA GeForce GTX 1080
I have not tried the .AppImage package yet, but will if has worked in the past.
Thanks.
Looks like two separate problems, so it may help to split them.
1. The chrome-sandbox message / apt can’t find it
The message points at a path that may not match what the package actually installed (or it could be left over from an older install). It’s worth checking what dpkg registered, since that will also tell you the exact package name to use with apt remove:
dpkg -l | grep -i etcher
dpkg -L <package-name-from-above> | grep chrome-sandbox
If dpkg -l lists it, sudo apt remove <that package name> should then work.
2. The empty window
Ubuntu-based releases since 24.04 restrict unprivileged user namespaces through AppArmor, and I’d expect newer Kubuntu releases to behave the same way. Electron apps that rely on the Chromium sandbox often start with a blank window, or don’t start at all, because of that. A quick test from a terminal:
balena-etcher --no-sandbox
If the window fills in, the sandbox is the cause. Rather than always running without it, you can make the helper setuid root at the path dpkg -L showed:
sudo chown root:root /path/to/chrome-sandbox
sudo chmod 4755 /path/to/chrome-sandbox
Since the window stayed blank after the first run, it may also help to clear the app’s saved settings/state before trying again.
3. AppImage as a fallback
The AppImage skips the package scripts entirely. On 24.04+ bases it needs libfuse2t64 (sudo apt install libfuse2t64). It can hit the same AppArmor restriction, so the --no-sandbox test applies there too.
If none of this changes anything, the terminal output from launching it would show where it stops.
Thank You for your reply. I successfully ran “sudo apt remove balena-etcher”, and it properly removed the package. However, due to system downtime, I had to take a different direction, and was able to make the Windows 10 Install USB drive with other software. Thank you for your efforts.
