I have a problem with the Resin OS 2.15.1+rev1 / Supervisor 7.16.6 …The node never restart the application… I use some Environment Variables and when I define some, the node never restart!!!
Service exited ‘main sha256:XXXX’
Killed service ‘main sha256:XXXX’
Installing service ‘main sha256:XXXX’
Installed service ‘main sha256:XXXX’
Starting service ‘main sha256:XXXX’
Started service ‘main sha256:XXXX’
Killing service ‘main sha256:XXXX’
This problem doesn’t happen in the version Resin OS 2.12.7+rev1 / Supervisor 7.4.3
I’m sorry… I return the node a previous version… I lost time with this issue… I need concentrate in my job instead Resin Issues… In this moment… I am deploying the Resin OS 2.13.6+rev1 Version
I think that this will be an instance of a known issue, but without seeing the device, I cannot confirm. Either way, if it is, I’m working on a fix now, and it should be released in the next week or two.
I wasn’t able to get to the device until now. I can check if this is the issue that I think it might be just with the application link though, no device required. Could you share this and enable app-wide support access please?
