The node doesn't restart with Environment Variable Changes
Lastly I have a problem with Resin.io. I change a Environment Variable but the node doesn’t restart. Then, I restart the node but the node doesn’t obtain the new value of the variable. Sometimes I purge the data and then the changes of the environment variable is taken.
Resin OS 2.12.7+rev1
Supervisor 7.4.3
Hi @leandro, sorry this thread slipped through the cracks. We actually have recently identified this bug and a fix should be released very soon. Sorry for the inconvenience.
Hey @shaunmulligan, we are currently experiencing the same problem with all the devices in a fleet and also with another test account with a different application…
Hello @Franky welcome to the balena forums. Could you please confirm your balenaOS version, device type and supervisor version?
Thank you
