I think I reproduced the error (it happened to me twice). I am using a raspberrypi3 and a microservices application. Confirmed, I reproduced the error (a third time).
First, a container sends a message to the supervisor API to restart the application. After that (before restarting the application) I powered off the device. Finally, I powered on the device, and it gets blocked!:
- All the services seems to be in status “Downloaded” or “Stopping”
- If I connect to the host and type
balena psI can see that only the supervisor and a few services are running. I tried to restart all the services, even the supervisor, but nothing solved the problem. - I cannot shutdown the device nor restart the application. The error is:
Device not found: DEVICE_ID(where DEVICE_ID is a sequence of numbers). - I tried to move the device to other application, but the problem is the same. The only thing I can do is re-flash the SD.
Do you know what can be happening?
PS: I am using and old docker base image (resin/raspberrypi3-python:3.6-slim). I’m gonna update it now, just in case this problem is related to the outdated docker base image.
