I’ve been trying to push updates today over the air and every build gets cancelled. Previously when a build would get cancelled usually another try or two would work but this afternoon I can’t get a single one through.
The only thing I see in the logs is:
[Info] Starting build for solvere-app, user adam_lee
[Info] Dashboard link: https://dashboard.balena-cloud.com/apps/1486429/devices
[Info] Building on arm01
[Info] Pulling previous images for caching purposes…
[Info] Starting to build api
[Info] Starting to build app
[Success] Successfully built service api
[Success] Successfully built service app
[Info] Uploading images
[Error] This build has been cancelled
Is there anywhere I can look to get more information?
But git push should work too. Is git push still not working for you? It’s odd. I just tested it and had no problems. I have also found backend (builder and git) log entries for your app name, “solvere-app”, but so far not an explanation for “This build has been cancelled”.
The one thing I have noticed now though is that the CLI never finishes. I get the unicorn and then it just sits. I wind up having to kill it every time even though every single build I’ve done since switching to the CLI has succeeded.
Hmm, that seems like the process is just continuing even and not getting the notification of the end of the stream from the builder. Can you create an issue to track this on https://github.com/balena-io/balena-cli/issues and detail your exact OS version and CLI version. If we can reproduce it, it should be fairly easy to fix. Thanks for the report!
