Etcher says - it looks like this is not a bootable image; the image does not appear to contain a partition table
while creating an ISO on SD: Etcher says ::
it looks like this is not a bootable image; the image does not appear to contain a partition table and mitht not be recognized or bootable by your device
well - this makes me wonder.
btw: first time i write to sd-cards.
in earlier times i had to write images to DVD
Hi @malaga What is the file you are trying to burn?
Did the burn succeed anyways, and you see contents on the card, or there’s no burn done?
I get the same error message when I try to burn a centos image to a USB stick. The image does flash okay but the USB won’t boot. The centos .iso file will start from Virtual Box. So I know the image is good…Based on other posts, it sounds like my iso image is missing the partition table. Just need to figure out how to add it.
What version of Etcher are you using and on what platform ? If you trying to flash a downloaded file you could post a link to the file and we can take a look if we can reproduce the problem.
Regards
Thomas
actually thinking about it, ISO images when designed for a CD do not necessarily need to contain a partition table. I am quite sure though that to boot from USB stick you will need one. Converting from one format to the other might not be trivial and you are probably better of downloading an image that is meant for flashing on a USB stick in contrast to being booted from CD.
Etcher documentation says:
Etcher copies images to drives byte by byte, without doing any transformation to the final device, which means images that require special treatment to be made bootable, like Windows images, will not work out of the box. In these cases, the general advice is to use software specific to those kind of images, usually available from the image publishers themselves.
The image is copied to drive byte by byte without any modification. If your ISO image isn’t hybrid (doesn’t contain partition, …), it won’t boot from the USB drive. I’d recommend to use Google with the bootable USB drive from an ISO image phrase. Lot of results / ways how to do it on Linux, Windows and macOS.
I also did ask the Etcher team if it’s something we have on our roadmap or not.
got a response from the team and they shared this issue you can track. For now, it’s not possible to achieve what you want with just balenaEtcher. And just to be sure, sharing again Why is my drive not bootable.
https://www.microsoft.com/en-us/software-download/windows10ISO
click on 64-bit,and after downloading flash it with etcher,you will see the notification MISSING PARTITION TABLE
Remember the problem happen with the latest version of etcher both in linux and windows(as I have tested)
Hello @Wasif – As Windows is not currently supported as a proper flashing target, you may receive errors as you have noticed. We do have a GitHub issue for this, located here: Support burning Windows images · Issue #210 · balena-io/etcher · GitHub
Thanks for the report though!
Six years of development still can’t flash a windows image, just shows the dedication and quality of the work, keep it up guys!
Tell me about it
