Hi, sorry really struggling to flash an ubuntu bootloader to transition from my old Macbook Pro to new framework laptop. I’ve tried everything I can see suggested on the forum including opening through sudo, re-downloading ISO, using an older linux ISO, rebooting, re-formating my (brand new) USB stick, but to no avail. Error code is below, if anyone could help me that would be amazing. Thanks in advance, Donald
index.js:2 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 2.1.2, Type = local
index.js:140 Spawning unpriviledged sidecar on port 3434
3index.js:2 Starting…
index.js:2 /Applications/balenaEtcher.app/Contents/Resources/etcher-util
index.js:2 etcher-ouekj6
index.js:2 Retrying to connect to child process in 1000… 1 / 10
index.js:2 Retrying to connect to child process in 1000… 2 / 10
index.js:2 Retrying to connect to child process in 1000… 3 / 10
index.js:2 Retrying to connect to child process in 1000… 4 / 10
index.js:2 CHILD READY
index.js:2 start heartbeat
index.js:2 CHILD LOG: Ready …
index.js:2 CHILD LOG: Scan requested
4index.js:2 Starting…
index.js:2 CHILD LOG: sourceMetadata requested
6index.js:2 Starting…
index.js:2 Spawning priviledged sidecar on port 3435
index.js:2 … with privileges …
index.js:2 etcher-d1uhm
index.js:2 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
index.js:2 params Object
index.js:2 CHILD LOG: write requested
index.js:2 CHILD LOG: Image: /Users/donaldwaters/Downloads/ubuntu-22.04.5-desktop-amd64.iso
index.js:2 CHILD LOG: Devices: /dev/disk7
index.js:2 CHILD LOG: Auto blockmapping: true
index.js:2 CHILD LOG: Decompress first: true
10index.js:2 Starting…
index.js:2 Flashing 1 device, 1% at 38.00 MB/s (total 38.00 MB/s) eta in 124s with 0 failed devices
9index.js:2 Starting…
index.js:2 Flashing 1 device, 1% at 35.10 MB/s (total 35.10 MB/s) eta in 133s with 0 failed devices
8index.js:2 Starting…
index.js:2 Flashing 1 device, 2% at 35.00 MB/s (total 35.00 MB/s) eta in 133s with 0 failed devices
7index.js:2 Starting…
index.js:2 Flashing 1 device, 2% at 30.20 MB/s (total 30.20 MB/s) eta in 153s with 0 failed devices
2index.js:2 Starting…
index.js:2 Flashing 1 device, 3% at 21.00 MB/s (total 21.00 MB/s) eta in 218s with 0 failed devices
index.js:2 Flashing 1 device, 3% at 19.90 MB/s (total 19.90 MB/s) eta in 230s with 0 failed devices
index.js:2 Flashing 1 device, 4% at 17.80 MB/s (total 17.80 MB/s) eta in 257s with 0 failed devices
index.js:2 Flashing 1 device, 4% at 18.30 MB/s (total 18.30 MB/s) eta in 248s with 0 failed devices
index.js:2 Flashing 1 device, 5% at 19.90 MB/s (total 19.90 MB/s) eta in 227s with 0 failed devices
index.js:2 Flashing 1 device, 5% at 19.90 MB/s (total 19.90 MB/s) eta in 226s with 0 failed devices
index.js:2 Flashing 1 device, 6% at 18.80 MB/s (total 18.80 MB/s) eta in 238s with 0 failed devices
index.js:2 Flashing 1 device, 6% at 18.80 MB/s (total 18.80 MB/s) eta in 237s with 0 failed devices
index.js:2 Flashing 1 device, 7% at 23.50 MB/s (total 23.50 MB/s) eta in 188s with 0 failed devices
index.js:2 Flashing 1 device, 7% at 27.20 MB/s (total 27.20 MB/s) eta in 162s with 0 failed devices
index.js:2 Flashing 1 device, 8% at 23.00 MB/s (total 23.00 MB/s) eta in 190s with 0 failed devices
index.js:2 Flashing 1 device, 8% at 21.50 MB/s (total 21.50 MB/s) eta in 203s with 0 failed devices
index.js:2 fail event
index.js:2 {size: 30784094208, isVirtual: false, enumerator: ‘DiskArbitration’, logicalBlockSize: 512, raw: ‘/dev/rdisk7’, …}
index.js:2 {name: ‘Error’, message: ‘ENXIO: no such device or address, write’, stack: ‘Error: ENXIO: no such device or address, write’, code: ‘EUNPLUGGED’, syscall: ‘write’, …}
index.js:2 Flash results {}
index.js:2 {}
index.js:2 Error: The writer process ended unexpectedly
at i (index.js:353:5238)
at t.createUserError (index.js:353:6464)
at p (index.js:140:43813)
at index.js:140:44129
at I. (index.js:140:41218)
at I.emit (node:events:518:28)
at e.exports.W (index.js:2:2204244)
at e.exports.emit (node:events:518:28)
at index.js:2:2180064
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
(anonymous) @ index.js:2
t.logException @ index.js:140
S @ index.js:140
processTicksAndRejections @ node:internal/process/task_queues:95
media/icon.png:1
GET file:///Applications/balenaEtcher.app/Contents/Resources/app.asar/.webpack/renderer/main_window/media/icon.png net::ERR_FILE_NOT_FOUND
index.js:353 Uncaught Error: Can’t set the flashing state when not flashing
at Object.i [as createError] (index.js:353:5238)
at e (index.js:140:33996)
at Object.g [as dispatch] (index.js:2:1357168)
at t.setProgressState (index.js:140:26391)
i @ index.js:353
e @ index.js:140
g @ index.js:2
t.setProgressState @ index.js:140
(anonymous) @ index.js:140
emit @ node:events:518
W @ index.js:2
index.js:2 etcher-uyjo5p
index.js:2 params {image: {…}, destinations: Array(1), SourceType: ‘File’, autoBlockmapping: true, decompressFirst: true}
index.js:2 CHILD LOG: Devices: /dev/disk4
index.js:2 Flashing 1 device, 0% at 34.00 MB/s (total 34.00 MB/s) eta in 139s with 0 failed devices
index.js:2 Flashing 1 device, 1% at 22.00 MB/s (total 22.00 MB/s) eta in 214s with 0 failed devices
index.js:2 Flashing 1 device, 1% at 28.20 MB/s (total 28.20 MB/s) eta in 165s with 0 failed devices
index.js:2 Flashing 1 device, 2% at 30.90 MB/s (total 30.90 MB/s) eta in 150s with 0 failed devices
index.js:2 Flashing 1 device, 2% at 22.50 MB/s (total 22.50 MB/s) eta in 206s with 0 failed devices
index.js:2 Flashing 1 device, 3% at 26.10 MB/s (total 26.10 MB/s) eta in 176s with 0 failed devices
index.js:2 Flashing 1 device, 3% at 28.80 MB/s (total 28.80 MB/s) eta in 159s with 0 failed devices
index.js:2 {size: 30784094208, isVirtual: false, enumerator: ‘DiskArbitration’, logicalBlockSize: 512, raw: ‘/dev/rdisk4’, …}
index.js:2 {}
S @ index.js:140
await in processTicksAndRejections (async)
tryFlash @ index.js:140
callback @ index.js:140
Ue @ index.js:2
Ge @ index.js:2
Or @ index.js:2
Tr @ index.js:2
De @ index.js:2
Rr @ index.js:2
Xt @ index.js:2
Zt @ index.js:2
t.unstable_runWithPriority @ index.js:2
qi @ index.js:2
Ie @ index.js:2
Yt @ index.js:2
r @ index.js:2
media/icon.png:1
i @ index.js:353
e @ index.js:140
g @ index.js:2
W @ index.js:2
