I’ve got the BBB online and can see it on the cloud.
I have CLI working and the latest Balina Sound Master
I’m getting the error message:
E: Unable to locate package python-gpiozero
Can anyone offer any advice?
Hi
can you please add more details about how and when you get that error message? Do you get it after a balena push?
best regards
federico
Yes - I used Balena Push to the device.
[snapcast-client] Using cache
[snapcast-client] ---> cc2a49dd502e
[snapcast-client] Step 9/9 : CMD [ "/bin/bash", "/usr/src/start.sh" ]
[snapcast-client] ---> f3fe52cdf9c0
[snapcast-client] Successfully built f3fe52cdf9c0
[bluetooth-audio] ---> Running in f8a0e6a7c317
[bluetooth-audio] Reading package lists...
[bluetooth-audio] Building dependency tree...
[bluetooth-audio] Reading state information...
[bluetooth-audio] E: Unable to locate package python-gpiozero
[bluetooth-audio]
[bluetooth-audio] apt failed, retrying
[bluetooth-audio]
[bluetooth-audio]
[bluetooth-audio] Removing intermediate container f8a0e6a7c317
[bluetooth-audio] The command '/bin/sh -c install_packages alsa-utils bluealsa bluez mplayer python-dbus python-gobject python-gpiozero' returned a non-zero code: 100
[Info] Uploading images
[Error] Service: bluetooth-audio
[Error] Error: The command '/bin/sh -c install_packages alsa-utils bluealsa bluez mplayer python-dbus python-gobject python-gpiozero' returned a non-zero code: 100
[Info] Built on arm03
Remote build failed
variable: "set DEBUG=1" on a Windows command prompt, "$env:DEBUG = 1" on
powershell, or "export DEBUG=1" on Linux or macOS.
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
Also I tried again but got this repeated :
[snapcast-server] invoke-rc.d: could not determine current runlevel
[snapcast-server]
[snapcast-server] invoke-rc.d: policy-rc.d denied execution of start.
[snapcast-server]
And at the end:
[Info] Built on arm01
Remote build failed
That’s a very unexpected error. Let me have a quick chat with the mainter of balena sound and I’ll get back to you
Thank you Federico
Hi Tony
So that package is not an official debian one, but it’s provided by raspberrypi. On raspberrypi base images, we also enable that repo, so apt-get finds and installs it. However, BBB boards don’t have it, hence the error message you’re getting
Please mind that balena-sound, at the moment, is a raspberrypi (like) project only, so it runs on the PI and on PI compatible boards (eg: balenaFin).
Having it run on other boards would be cool: can you try commenting out python-gpiozero from the dockerfile, and see what happens?
Best regards
federico
I’ll give it a try.
Tony
I deleted the
** python-gobject
line and the ‘’ on the line before on both files Dockerfile.template and Dockerfile.aarch64
and installation completed.
I’m not intending to use bluetooth - I’ll let you know if it works in action.
yes @ffissore - it works with those lines removed!
It’s a bit glitchy? Tiny drop out every 5 seconds or so.
Do you know what services are essential?
Check out https://github.com/balenalabs/balena-sound/#customize-your-balenasound-experience for a good place to start looking what you can enable/disable without modifying the project.
Thanks @robertgzr
