I am using balenaEtcher to restore images to CF or CFast cards. The images were generated by reading the contents of a disk of same type (including size) using e.g. dd-tool on a Linux machine.
Everything worked fine with balenaEtcher version 1.5.50, but after upgrading to version 1.5.100 I see the following error behaviour:
Etcher console output (Image file path and name modified):
Tue Jun 30 2020 12:58:37 GMT+0200 (Mitteleuropäische Sommerzeit) Drive unplugged ({“image”:“C:\FilePath.img”,“drives”:[{“size”:2048901120,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“H:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“H:\”}],“description”:“Multi Flash Reader USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“893f6a1a-25f0-495e-8b12-361350c1a354”,“flashInstanceUuid”:“893f6a1a-25f0-495e-8b12-361350c1a354”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“5a183c62-71b7-4996-b725-30b39228b2c3”,“flashingWorkflowUuid”:“aaae093c-8210-46a1-ad3a-48df3a673603”})
gui.js:7847 Flashing 0 devices, 99% at 15.20 MB/s (total 0.00 MB/s) eta in 0s with 1 failed device
gui.js:126777 Finish: 2047868928
gui.js:126777 Terminating IPC server
gui.js:126777 Flash results Object
gui.js:126777 Tue Jun 30 2020 12:58:40 GMT+0200 (Mitteleuropäische Sommerzeit) Done ({“image”:“C:\C:\FilePath.img”,“drives”:[{“size”:2048901120,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“H:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“H:\”}],“description”:“Multi Flash Reader USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“893f6a1a-25f0-495e-8b12-361350c1a354”,“status”:“finished”,“flashInstanceUuid”:“893f6a1a-25f0-495e-8b12-361350c1a354”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“errors”:[{“name”:“Error”,“code”:“EUNPLUGGED”,“syscall”:“write”,“errno”:-4094,“device”:"\\.\PhysicalDrive2"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:2047868928,“sourceMetadata”:{“size”:2048901120,“name”:“FileName.img”,“blocks”:[{“blocks”:[{“offset”:0,“length”:2048917504}]}],“blockmappedSize”:2048917504},“sample”:0.1,“applicationSessionUuid”:“5a183c62-71b7-4996-b725-30b39228b2c3”,“flashingWorkflowUuid”:“aaae093c-8210-46a1-ad3a-48df3a673603”})
gui.js:126777 Tue Jun 30 2020 12:58:40 GMT+0200 (Mitteleuropäische Sommerzeit) SafeWebview loaded ({“event”:{“id”:13,“url”:“https://www.balena.io/etcher/success-banner/?etcher-version=1.5.100&api-version=2&optOutAnalytics=true",“method”:“GET”,“timestamp”:1593514720882.52,“resourceType”:“mainFrame”,“ip”:“34.206.168.28”,“fromCache”:false,“statusLine”:"HTTP/1.1 200 OK”,“statusCode”:200,“responseHeaders”:{“Accept-Ranges”:[“bytes”],“Access-Control-Allow-Headers”:[“Origin, X-Requested-With, Content-Type, Accept”],“Access-Control-Allow-Origin”:["*"],“Cache-Control”:[“public, max-age=0”],“Connection”:[“keep-alive”],“Content-Encoding”:[“gzip”],“Content-Type”:[“text/html; charset=UTF-8”],“Date”:[“Tue, 30 Jun 2020 10:58:53 GMT”],“Etag”:[“W/“541f-17300538f58"”],“Last-Modified”:[“Mon, 29 Jun 2020 13:45:43 GMT”],“Server”:[“Cowboy”],“Transfer-Encoding”:[“chunked”],“Vary”:[“Accept-Encoding”],“Via”:[“1.1 vegur, 1.1 vegur”]},“referrer”:”",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“5a183c62-71b7-4996-b725-30b39228b2c3”,“flashingWorkflowUuid”:“aaae093c-8210-46a1-ad3a-48df3a673603”})
Problem appears for compressed (.xz) or uncompressed Images. Please also note that on my machine for getting the required administrative privileges I need to enter credentials different from the user credentials I am logged in with.
At the moment I got around the problem by reverting Etcher software to version 1.5.50. But of course it would be great to stay able to use latest software.
