Fail when install
When I pick file I get message
Need help
Hey there @elacid, welcome to the forums!
What type of image are you attempting to flash? This warning is because balenaEtcher looks for a GPT or MBR partition table in disk images and warns you if it can’t find one.
Depending on the device that you’ll be using the flashed disk with, it might still boot.
If you are flashing a Windows image, you may need to follow the workarounds here: etcher/USER-DOCUMENTATION.md at master · balena-io/etcher · GitHub
I hope this helps!
Hello I saw this error first time but I will do some RnD regarding this if I will get some solution I will let you know
I have this same error..
Hey there @rahulp411, welcome to the forums! Could you answer the same questions I asked above?
If you are flashing a Windows image, you may need to follow the workarounds here: https://github.com/balena-io/etcher/blob/master/docs/USER-DOCUMENTATION.md?d_id=7df3f866-30a1-4e1b-bb9d-5761c9a45a6dR#why-is-my-drive-not-bootable
