Error: No handler registered for 'disable-screensaver'
Etcher: 1.18.13
OS: Debian 11 (bullseye) KDE
I launch Etcher with common user. When I select targed device Iam asked for root password, so I pass the root password, then I click on button Flash and after a second appears pop-up
Attention,
Something went wrong. If it is compressed image, check that the archive is not corrupted.
The writer process unexpectedly.
medvide@dell-e6410:~$ balena-etcher
[7869:1127/191533.299269:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
Language changed to: en
packageUpdatable false
ready-to-show: 1.780s
Error occurred in handler for 'disable-screensaver': Error: No handler registered for 'disable-screensaver'
    at WebContents.<anonymous> (node:electron/js2c/browser_init:2:89123)
    at WebContents.emit (node:events:513:28)
    at WebContents.emit (node:domain:489:12)
    at emitter.emit (/opt/balenaEtcher/resources/app/generated/etcher.js:1:213380)
Error occurred in handler for 'enable-screensaver': Error: No handler registered for 'enable-screensaver'
