Out of curiosity and willingness to learn I would like to build balenaOS. I wanted to try out raspberry pi 3 64 bit.
I followed the instructions from GitHub - balena-os/balena-raspberrypi: Balena support for RaspberryPI boards and tried out 1. ./balena-yocto-scripts/build/barys -m "raspberrypi3-64" or 2. the way via /balena-yocto-scripts/build/barys --remove-build --dry-run+ config change MACHINE ?= “raspberrypi3-64” then source and then bitbake balena-image
I downgraded docker version to 20.10.13 due to another problem. ( error building mkfs-hostapp-native.bb recipe - #4 by alexgg )
It is now running till:
I tried it out on two different machines. Ubuntu 22.04.2 LTS and Tuxedo OS 2 (Linux - based on Ubuntu)
From the error you can see that it has to do with runc and cgroup v2 but I am super uncertain if downgrading to cgroup v1 is the way to go here or not or if there is another core probelm. Thx for any help
