I have an error when I build balenaOS for up-board machine.
Error logs are in following gist : https://gist.github.com/quentin-burg/cdf4a6584b4758ba3a52c489dbf32f40
This error appear when I try to add a bbappend recipe to have a custom plymouth and I don’t understand why.
Does anyone have an idea ?
floion
August 26, 2019, 10:27am
3
Hi. Can you paste the command you used to clone the repository? And then paste the command you used to build it?
Hello @floion ,
I clone repository with git clone --recursive https://github.com/balena-os/balena-up-board.git.
The command to build image is bitbake resin-image-flasher.
floion
August 26, 2019, 12:11pm
7
Hi. The command “bitbake resin-image-flasher” would not work. You’d need to specify a machine. So can you paste exactly the command you used after you cloned?
The machine is set in local.conf file :
MACHINE ?= "up-board"
I have a script that runs :
balena-yocto-scripts/build/build-device-type-json.sh
source layers/poky/oe-init-build-env build
floion
August 26, 2019, 1:41pm
11
You could run barys instead. And you could also make use of shared sstate and shared downloads by doing so: "barys -m up-board --shared-downloads --shared-sstate ". And then you can re-use these 2 directories for future builds so that it speeds-up download tasks and compile tasks.
For the problem at hand, do you happen to have the aufs module available on your build machine? I believe the issue is that you are lacking this module as the Up Board uses aufs and it needs to have it available at build time.
Thank you for these tips.
The aufs module is available at build time.
I copied the result of the lsmod command:
Module Size Used by
veth 16384 0
aufs 360448 0
ipt_MASQUERADE 16384 2
nf_nat_masquerade_ipv4 16384 1 ipt_MASQUERADE
nf_conntrack_netlink 36864 0
nfnetlink 16384 2 nf_conntrack_netlink
xfrm_user 36864 1
xfrm_algo 16384 1 xfrm_user
iptable_nat 16384 1
nf_conntrack_ipv4 16384 3
nf_defrag_ipv4 16384 1 nf_conntrack_ipv4
nf_nat_ipv4 16384 1 iptable_nat
xt_addrtype 16384 2
iptable_filter 16384 1
xt_conntrack 16384 2
nf_nat 24576 2 nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack 114688 6 nf_conntrack_ipv4,nf_conntrack_netlink,nf_nat_masquerade_ipv4,xt_conntrack,nf_nat_ipv4,nf_nat
br_netfilter 24576 0
bridge 135168 1 br_netfilter
stp 16384 1 bridge
llc 16384 2 bridge,stp
overlay 49152 0
intel_rapl 20480 0
sb_edac 24576 0
cirrus 24576 1
edac_core 57344 1 sb_edac
ttm 98304 1 cirrus
crct10dif_pclmul 16384 0
crc32_pclmul 16384 0
drm_kms_helper 155648 1 cirrus
ghash_clmulni_intel 16384 0
drm 360448 4 cirrus,ttm,drm_kms_helper
intel_rapl_perf 16384 0
evdev 24576 2
serio_raw 16384 0
button 16384 0
ip_tables 24576 2 iptable_filter,iptable_nat
x_tables 36864 5 ip_tables,iptable_filter,ipt_MASQUERADE,xt_addrtype,xt_conntrack
autofs4 40960 2
ext4 585728 1
crc16 16384 1 ext4
jbd2 106496 1 ext4
crc32c_generic 16384 0
fscrypto 28672 1 ext4
ecb 16384 0
mbcache 16384 2 ext4
ata_generic 16384 0
crc32c_intel 24576 2
aesni_intel 167936 0
xen_netfront 28672 0
xen_blkfront 36864 2
aes_x86_64 20480 1 aesni_intel
glue_helper 16384 1 aesni_intel
lrw 16384 1 aesni_intel
gf128mul 16384 1 lrw
ablk_helper 16384 1 aesni_intel
cryptd 24576 3 ablk_helper,ghash_clmulni_intel,aesni_intel
psmouse 135168 0
ata_piix 36864 0
i2c_piix4 24576 0
libata 249856 2 ata_piix,ata_generic
scsi_mod 225280 1 libata
EDIT : le build échoue seulement quand j’ajoute la recette qui nous permet de jouer une animation au démarrage de la board (plymouth_0.9.2.bbappend in a custom layer).
When I take out this recipe, the build goes normally.
imrehg
August 26, 2019, 2:14pm
14
can you share that custom layer with us / the source of that plymouth_0.9.2.bbappend? Maybe it has some syntax or other issues?
Hi @imrehg ,
Here is the plymouth recipe :
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
SRC_URI_append = " \
file://0001-plymouth-default-theme-is-cutii.patch \
file://cutii-theme.tar.bz2 \
file://cutii-linear-theme.tar.bz2 \
do_install_append() {
# Theme based on progress
install -d ${D}/${datadir}/plymouth/themes/cutii
install ${WORKDIR}/cutii/cutii.plymouth ${D}/${datadir}/plymouth/themes/cutii
install ${WORKDIR}/cutii/*.png ${D}/${datadir}/plymouth/themes/cutii
# Theme based on time
install -d ${D}/${datadir}/plymouth/themes/cutii-linear
install ${WORKDIR}/cutii-linear/cutii-linear* ${D}/${datadir}/plymouth/themes/cutii-linear
install ${WORKDIR}/cutii-linear/*.png ${D}/${datadir}/plymouth/themes/cutii-linear
# two-step plugin
install -d ${D}${nonarch_libdir}/plymouth/
install ${WORKDIR}/build/src/plugins/splash/two-step/.libs/two-step.so ${D}${nonarch_libdir}/plymouth/
