How to connect two cameras to the balenaFin? Any example?
@calgalli this is a feature that’s only available on the v1.1, so the first step is to flip the switch on the bottom of the board (under the Compute Module if you have one inserted), to the CAM1 position. This will enable you to connect two cameras.
We don’t yet have an example setup, but that will be available soon.
thank you very much.
