i have a problem with our gateway. the gateway is running and is forwarding packets. however, it seems the docker container is not running/loaded. when i try to start a terminal, i get an error “Container access is only available for running containers” when i choose main as the target. i can however, choose host and im able to login to the host.
Hi @maoie, do you still have this issue? This error hints that the app container was not running at the time, so the fact that your gateway application was running normally makes it a bit hard to tell what the issue was. Let us know if this has been resolved in the meantime and we will take it from there.
