Disable bluetooth-audio service
I have BalenaSound running on an RPi 2 that does not have bluetooth, When I restart the device, the bluetooth-audio service keeps failing to start and loops. I have to stop it manually via the web portal.
Is there a way to prevent the service from starting by setting a variable (like the variable DISABLE_MULTI_ROOM to prevent the fleet-supervisor and the rest from starting)?
Thank you.
Hi @densmtl, welcome to the forums!
There isn’t currently a way to disable Bluetooth with an environment variable, but that’s a good idea! I encourage you to submit that as a feature request.
In the meantime, there are a couple of things you could experiment with:
  • You could try changing the restart directive in docker-compose.yml from always to never. (See here for more details on your options.)
  • Alternately, you could try commenting out the entire bluetooth-audio stanza in docker-compose.yml.
Give those a try and let us know how they go!
All the best,
Hugh
Hi @saintaardvark,
Thank you for the suggestions. I submitted a feature request and commented out the bluetooth-audio section in the docker file.
Cheers,
Dens
Actually I just saw a PR that would probably solve my issue… :slight_smile:
Hi, the issue attached to this ticket was closed, and a resolution provided. See https://github.com/balenalabs/balena-sound/issues/196#issuecomment-641384693 got details.
