I have Nvidia Jetson Nano 4GB Dev Kit. I didn’t find suitable Balena OS image for it.
Its the “Nvidia Jetson Nano SD-CARD” one
Hey @suyash-chavan the OS that nmaas87 should work, if you search nvidia jetson nano on this page: balenaOS - Run Docker containers on embedded IoT devices you should find it
Hey Xavierchan,
I would recommend that you double check which Nvidia Jetson Dev Kit you have, if its the 4 GB or the 2 GB variant. Then download the development image from Run containers on embedded edge devices - balenaOS
(for the 2 GB Version this one: Nvidia Jetson Nano 2GB Devkit SD, for the 4 GB Version this one: Nvidia Jetson Nano SD-CARD).
I would then go ahead, flash that image onto an SD Card and try booting the unit.
As soon as this works out, you can try getting it to work with openBalena ![]()
Also, openBalena 3.2.2 is 2 years old now, please try upgrading to the latest version, 3.8.2 GitHub - balena-io/open-balena: Open source software to manage connected IoT devices at scale
Hm, I don’t recall seeing the mounting issues.
Maybe @cmfcruz can put some engineer for the Jetson Nano balenaOS image in contact with you to look at the error you’re seeing ![]()
@xavierchan Did you find a solution? Having the same issue.
