Device Pinning Broken & Outage
All our devices have been reverted to the application latest version (which in the case of our development devices is arbitrary). Pinning is broken.
Attempts to manually move things forward also seem to be unavailable as the update server is giving 503’s (probably due to the number of fleets that have been broken).
Hi there @splitice,
There was an incident earlier today that affected device pinning. That incident has now been sorted out and all devices should be functioning as normal once again. You can learn a bit more about the timeline of the incident here: https://status.balena.io/incidents/g65wqm18b8nr. We will also be posting a postmortem later on describing the incident in more detail.
Please let us know if you continue to observe any abnormal behavior!
Hi, we have done a thorough investigation of the device pinning incident earlier this week. We have published our post-mortem write-up, which can be found here: https://status.balena.io/incidents/g65wqm18b8nr
If you have any questions or feedback, please don’t hesitate to reach out to us!
