Hi there,
We’re running a few tests externally from our board-based fleet, mostly on OS X and in-cloud Linux distros. These are Intel-based systems and have a different hardware makeup compared balenaOS flavours currently offered.
Out of curiosity, is there a balenaOS version we can use for the above mentioned cases? Ideally we want to setup Docker on 2-3 systems, create a new Application in our Balena Cloud and conduct our tests there. This is mostly for running coordinated tests. I realize that Balena is designed for IoT fleets so this use case may not be supported easily.
David
