We’re starting to use different Resin applications to manage staging vs. production environments (the complete lack of UI support for the device-specific commits feature has turned us off that approach).
At the moment, it appears that cross-app moves (when I upgrade a device into the production environment/app, for example) don’t use the delta process, even though technically it seems like it shouldn’t make the difference.
If so, could you make delta updates work across application moves, since our staging/production applications are near-identical?
Thanks a lot,
-robin
