.deb version wants to delete Discord
Hello, I wanted to install Etcher on my KDE neon system and I used the .deb version because the AppImage version fails when I click on flash.
For some reason the .deb version wants to delete Discord else it won’t install.
Please fix that. :slight_smile:
I can’t reproduce this.
Which kde neon version are you using ?
How did you install discord ?
Which etcher deb version are you using ?
I used the .deb file from Discord’s website. My KDE neon version is 5.18.1.
I used “balena-etcher-electron_1.5.79_i386”.
What is the output of dpkg --no-pager -l discord ?
Please try the amd64 version from here https://github.com/balena-io/etcher/releases/download/v1.5.79/balena-etcher-electron_1.5.79_amd64.deb ?
Or do you have a 32bit computer ?
