Since the last update on the UI I can no longer filter applications.
Maybe this helps:
This also applies to filtering in the terminal. Same error.
This should have gone under balena cloud. Sorry.
This is the error message that seems to cause this:
vendor~scripts.a7db9d3f02196982a880.chunk.js:31 Unhandled rejection Error: Mixpanel error: NaN at https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:130:395067 at r (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:130:442156) at XMLHttpRequest.o.onreadystatechange (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:130:443107)From previous event: at B.H [as _captureStackTrace] (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:31:36205) at B._then (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:31:62656) at B.then (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:31:61006) at https://dashboard.balena-cloud.com/scripts.bcb086b5d1581686f349.js:1:287049 at Pa (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:77699) at us (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:84828) at cs (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:85008) at ds (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:91146) at $s (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:98488) at Zs (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:97868) at iu (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:99243) at Ln (https://dashboard.balena-cloud.com/vendor~scripts.a7db9d3f02196982a880.chunk.js:89:30629)
Hello, thanks for reporting this. We are aware of the issue with the filters and are already working to have it fixed and deployed soon. We are tracking progress in this I have attached it to the ticket so as soon as the issue is closed you will get notified by as support agent.
This is now fixed.
