Could not detect project type: Resolution could not be performed
When pushing the Balena Dash app i get the folowing error :
[Info] Starting build for BelenaDash, user jeffrey2
[Info] Dashboard link: https://dashboard.balena-cloud.com/apps/xxxxxxxxxxxx/xxxxxx
[Error] Could not detect project type: Resolution could not be performed
anyone ? help ?
Hi @DW_Jeff, first of all welcome to balena community : )
Checking the earlier forum posts I see that another user had this issue and he resolved it by updating the docker compose file to match the folder names:
Let us know if that doesn’t help.
Then we would need more info from you to continue troubleshooting.
Hi Gelbal,
i’m totally new to this so maybe i’m forgetting something…
I tried to follow the instructions, figured out that i needed to install git and balenacloud on my desktop to push the git repo to the raspberry. I think I understood it all untill i reached the " Deploying code" chapter. So i installed git for windows and downloaded the app and installed the cli tools and then i tried to push it to the raspberry, after that i got the error.
Is there any other noob manual or did i forget something ? Maybe i’ll write a manual after i’m done… to help other “idiots” :wink:
FYI i did not put a DockerFile into my local repo… i have the idea thats the step i am missing…
Got it working by running the balena push command in the downloaded git folder… then it worked…
Got to see the unicorn… So installation worked…
Logs give a lot of error messages… and the Device Variable doesnt work so still not functional…
scheduler /bin/sh: /usr/src/start.sh: not found
wpe standard_init_linux.go:195: exec user process caused “no such file or directory”
I installed it with windows 10 and i saw that there were problems… ( Docker file does not COPY files in subdirectories correctly when pushing to a local Balena device from Windows 10 )
anyone with a solution ?
We are performing some tests with the project and will be getting back to you as soon as we have results.
Hey @DW_Jeff,
Two things, which device are you running this project on?
Have you entered all the environment variables for the project?
Cheers
In my case I had named my file dockerfile.template instead of capital D, Dockerfile.template :frowning:
