We need container engine for our edge device which is based on i.MX6 solo x architecture. It runs custom built embedded linux which uses 4.9.141 kernel(Yocto 2.5). Is there is any port available for this architecture?
srikanth
srikanth
Hi @srikanthshapz,
Balena engine should work on your device.
You can try installing it with this command on your boards: curl -sfL https://balena.io/engine/install.sh | sh
Or you could try to compile it yourself in the yocto environment from our layers using this recipe as starting point: https://github.com/balena-os/meta-balena/tree/master/meta-resin-common/recipes-containers/balena
Or you can directly download it from this link: https://www.balena.io/engine/
