balenaEngine Yocto Layer?
Hello :slight_smile:
I wanted to ask if there is actually seome balenaEngine Yotco Layer, so that one can include balenaEngine easily into a normal Yocto Warrior build?
I presume there are also some changes to the kernel config needed, so any ideas are very appreciated :slight_smile:
Best regards,
Nico
We integrate the engine into balenaOS like this: https://github.com/balena-os/meta-balena/blob/master/meta-balena-common/recipes-containers/balena/balena_git.bb
You could take that and turn it into a layer - that would be a very nice project :slight_smile:
Or as an alternative (and the probably easier option) add meta-balena layer but not build balenaOS. Instead build poky. You will only need to add the balena package to pokyโ€™s core-image-minimal
cc @zubairlk
I have just created something like that here: https://github.com/3mdeb/meta-balena-engine/commits/master
Feel free to try it out. I have just tested out the basics.
Hi @macpijan โ€“ welcome to the forums, and thanks for letting us know about your work! Weโ€™ve let our OS team know that they should have a look.
All the best,
Hugh
Hi @macpijan - thanks for your answer and cool project.
I currently changed my approach and solved the problem differently, but I really gonna keep this post in mind as soon as I build an Yocto image again in the future :slight_smile:
Thanks for the info :slight_smile:
Best regards,
Nico
