Connect to wifi
@Jgilbert great news! Glad this is sorted now!
Yes; I’ll update when the new image is out :slight_smile:
Alex
Hi @Jgilbert,
The image for the WLAN fixes is available now - https://github.com/balena-os/pi-gen/releases/tag/v0.1.0.
Thanks for your patience on this!
@bucknalla Thanks! I have downloaded the image, and was able to update it without issues. For future reference, upgrading the OS loses the driver again.
Thank you again!
Hello Everyone,
I have been following these details in an attempt to get a baked Yocto image with the fin running. Most of it works, except wlan.
I was wondering if there is (?) a detail explanation on the steps mentioned here:
Thanks for the great work!
Hi, we do not have any docs on how to integrate the proprietary WiFi driver, but I can point you to the corresponding recipes and patches we use:
Including the driver:
And those are the two patches that we include in our OS on top of the raspberrypi kernel:
Please check those and let us know if you have any questions regarding them.
Zahari
I appreciate the commentary and support in this thread and was able to get this fixed. However I skipped the “disable opensource wifi/bt driver” because I wasn’t sure how to do that.
Here are some more in depth steps to accomplish this.
My Situation
I have an image developed on RPI3/Raspbian that I’d like to flash on to the MMC and deploy on a BalenaFin v1.1.1. The BalenaFin flavored Raspbian is still on Debian Stretch and I need Python 3.7 among other systemd tweaks I’ve made to this image. I should note that my image started from a Raspbian Stretch image and then dist-upgraded to Buster.
Update the device tree stuff
On the boot partition change /config.txt to have
dt-overlay=balena-fin
Then copy the balena-fin.dtbo from their repository to /overlays/balena-fin.dtbo and overwrite the one that exists.
Notes
In the BalenaFin flavored Raspbian I noticed that it actually has /overlays/balena-fin-updated.dtbo and dt-overlay=balena-fin-updated in the /config.txt. I did not do this. Perhaps the -updated is because the Original Raspbian Stretch image seems to have shipped with a balena-fin.dtbo because there was already one there!
I did remove my other dt-overlays which activated a RTC and it does seem like this image boots and sets the right clock value. Nice! However it was hanging for 90 seconds on waiting for /dev/serial1 and wlan0 was not to be found once I hit the console.
Get the WiFi to work
Download the deb file from their debian repo
wget https://dl.bintray.com/balenaos/raspbian/pool/main/s/sd8887-mrvl/sd8887-mrvl_0.0.4-1_all.deb
Install needed dependencies
sudo apt-get install dkms bc raspberrypi-kernel-headers
Install proprietary wireless driver
sudo dpkg -i sd8887-mrvl_0.0.4-1_all.deb
…and it will recompile the modules against the wifi. I rebooted for good measure and wlan0 shows up!
Notes
I did not add the repository to sources.list because I know Buster is not officially supported and did not want to deal with that complexity at this time. This device is to be deployed in a remote location with no internet so updates do not need to be automatic or anything like that.
During boot, it does take about 10 more seconds waiting for /dev/serial1 before networking is established. Good enough for now.
