I am trying to flash HomeAssistantOS to an Odroid N2 with an eMMC (Red) 124 GB storage. I have tried flashing straight to the eMMC, and flashing to the Odroid with the eMMC attached to it.
When flashing directly to the eMMC, it usually doesn’t show up as a drive, but when it does and I run Etcher, I get this error: erroutput.txt (734.2 KB)
You may notice the error is just child-writer.js
When flashing to the Odroid while the eMMC is connected, it shows up as a drive as long as I have run
ums /dev/mmcblk0
in the Odroid shell. Then I get the same error.
Since the first line of the error is that it won’t run etcher, I guessed that Windows Defender might be preventing me from flashing, so I turned it off, tried again as admin, and the error is the same for both methods.
I think the issue is with this file somehow, my security settings are still blocking something or I am missing some dependency/setup, but I don’t see a clear route to go from here.
Hello, it looks like possibly there is an issue reaching the URL of the file to flash. What URL are you using? If you paste it into a browser, does it download the file? If so, can you try flashing the downloaded file rather than using a URL? (Assuming you are following the steps here: ODROID - Home Assistant)
Thanks @alanb128 !
That is indeed where I was following instruction; that is my bad as I meant to include that with my error description but forgot to.
I have tried your suggestion of downloading it first instead of flashing from URL and I am finally able to flash. However my flashing fails at 100%, although it appears to have finished. A quick read of the error gives me the impression that the error is irrelevant to the OS itself, so I will connect it to a screen when I am home and see if it works and get back. Until then, here is a copy of the output, with the error being the last 2 lines of the output
