I’m running chromium browser in kiosk mode in a docker container. The page loads a login screen. You sign in and the page gives you a cookie so that you never have to login again. The set up all seems to work fine except for saving cookies which is crucial for this. I’m wondering where this is going wrong. I’m using the balena project found below:
here on github.
Maybe I need to try changing my flags on start up? right now they are:
chromium-browser --kiosk --disable-infobars $URL_LAUNCHER_URL --disable-gpu
The site that it opens into to is not a local one but instead a remote site at an ip address. so the issue is not the common file:// prefix I’ve seen so much of when researching this. I am going to an actual site.
I have to use chromium because wpe/webkit doesn’t support autoplay for videos
I tried using this project here to see if it was specific to the build or chromium. This project runs firefox but cookies don’t seem to persist here either.
Is there something about a virtual environment like docker where data doesn’t persist?
Some logs from chromium although they seem unrelated:
X.Org X Server 1.20.4
29.01.20 12:53:06 (-0800) browser X Protocol Version 11, Revision 0
29.01.20 12:53:06 (-0800) browser Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
29.01.20 12:53:06 (-0800) browser Current Operating System: Linux bk-rpi-629ec76 4.19.71 #1 SMP Mon Jan 6 19:29:19 UTC 2020 armv7l
29.01.20 12:53:06 (-0800) browser Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1080 bcm2708_fb.fbheight=1920 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=null rootfstype=ext4 rootwait vt.global_cursor_default=0 root=PARTUUID=0653c4e0-02 rootwait
29.01.20 12:53:06 (-0800) browser Build Date: 05 June 2019 12:49:54PM
29.01.20 12:53:06 (-0800) browser xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
29.01.20 12:53:06 (-0800) browser Current version of pixman: 0.36.0
29.01.20 12:53:06 (-0800) browser Before reporting problems, check http://wiki.x.org
29.01.20 12:53:06 (-0800) browser to make sure that you have the latest version.
29.01.20 12:53:06 (-0800) browser Markers: (--) probed, (**) from config file, (==) default setting,
29.01.20 12:53:06 (-0800) browser (++) from command line, (!!) notice, (II) informational,
29.01.20 12:53:06 (-0800) browser (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
29.01.20 12:53:06 (-0800) browser (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jan 29 20:53:06 2020
29.01.20 12:53:06 (-0800) browser (==) Using system config directory "/usr/share/X11/xorg.conf.d"
29.01.20 12:53:21 (-0800) browser [139:366:0129/205321.397269:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
29.01.20 12:53:21 (-0800) browser [139:366:0129/205321.741725:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
29.01.20 12:53:21 (-0800) browser [139:366:0129/205321.742165:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
29.01.20 12:53:22 (-0800) browser [139:380:0129/205322.697631:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
29.01.20 12:53:22 (-0800) browser [139:380:0129/205322.700946:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
29.01.20 12:53:22 (-0800) browser [139:380:0129/205322.704045:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
