Hi
I have problems persisting data to the host OS. I have followed this guide: https://www.balena.io/docs/learn/develop/runtime/#persistent-storage and read several post on the forum with no luck.
My project is based on the Google Cloud IoT integration: https://www.balena.io/docs/learn/develop/integrations/google/
and i need to persist certificate files between restarts of my Raspberry Pi
My understanding of how the persistence of data works with the Balena container is that everything placed in the /usr/src/app/data folder of the project will be persisted into the hostOS at /var/lib/docker/volumes/resin-data/_data as my Balena OS version is 2.29.2+rev2 and then be accessible from /usr/src/app/data folder in the container automatically after restart.
So the gist of my bash script generating the certificates is as follows:
#!/bin/bash
if [ ! -f ./data/service.json ]; then
mkdir -p data
echo "$GOOGLE_IOT_SERVICE_JSON" > data/service.json
cd data
# Create keys
openssl req -x509 -newkey rsa:2048 -keyout rsa-priv.pem -nodes -out rsa-cert.pem -subj "//CN=unused"
openssl ecparam -genkey -name prime256v1 -noout -out rsa-ec_private.pem
openssl ec -in rsa-ec_private.pem -pubout -out rsa-ec_public.pem
cd -
fi
node dist/main.js
However as mentioned, the data is not persisted and new certificates are generated every time the Pi is restarted.
When pushing the project to the Pi I am able to cd to the var/lib/docker/volumes/resin-data/_data folder in the hostOS but it remains empty.
I have attempted pushing from both Windows and mac.
When running the bash script on my dev computer, it works perfectly.
I have assumed it just working out of the box, but is there any settings or configs i need to set before data persistency works?
You want /data not /usr/src/app/data
#!/bin/bash
if [ ! -f /data/service.json ]; then
echo "$GOOGLE_IOT_SERVICE_JSON" > /data/service.json
pushd /data
# Create keys
popd
fi
node dist/main.js
(I used pushd and popd because I wasn’t familiar with cd -)
Hi @TobiasEmil,
@jason10 response is indeed accurate, you need to use /data from within your container to access the persistent storage directory.
Just to correct the above, as mentioned earlier, /usr/src/app/data should be /data. Moreover, instead of /var/lib/docker/volumes/resin-data/_data, the correct host OS path is /var/lib/docker/volumes/<APPID>_resin-data/_data.
Please also keep in mind that the resin-data named volume is only automatically linked in a single-container application. If you have a docker-compose.yml in your project then you should also specify the used volumes in there.
Give us a note if you still face issues with using persistent storage on your app.
Kind regards,
Thodoris
Hi @TobiasEmil,
TobiasEmil:
Just to correct the above, as mentioned earlier, /usr/src/app/data should be /data. Moreover, instead of /var/lib/docker/volumes/resin-data/_data, the correct host OS path is /var/lib/docker/volumes/_resin-data/_data.
Kind regards,
Thodoris
I got it to work from your advice, thanks! I have spent ages figuring out the right paths as my work environment is Windows.
Now that the /data dir does not exists in my workdir anymore my JS application has trouble finding the certificates when running on my dev machine:
const privateKeyFile = '/data/rsa-priv.pem'
const jwt = this.createJwt(this.projectId, privateKeyFile, this.algorithm)
This is not at problem when pushing to the device, however I when i run the bash script and subsequently the JS app, the app looks for the file in ‘C:\data’
I have fixed this right now by copying the files from the /data folder into the workdir again in my bash script:
mkdir -p ./data
cp -r /data/* ./data
node dist/main.js
and changed the file path in the JS file to:
const privateKeyFile = './data/rsa-priv.pem'
But om not sure whether this is a preferable way to handle it?
I’d probably go with changing the file path in the JS file to the persistent storage
Or, you can add a link from the persistent storage to the local directory:
ln -s /data ./data
Or, you can use a variable in your JS file, and fetch the value from the environment or rewrite the variable/marker when you deploy.
Questions to ask:
- Will this be part of a multicontainer build, and might you have to share the keys across containers. If yes, you will eventually have to move from using /data to /some-other-shared-volume that you will have to specify in your docker-compose.yml file
- Is this path likely to change across deployments? If you have non-balena.io deployments where the path might be different, you might want to use a variable or a deployment time rewrite.
- Do you already have configuration values in a configuration file or in the runtime environment that this path could move into?
Thank you for the answer!
The application will remain fairly simple so I do not plan on dividing it into multiple containers for now
I think I will go with the link, as it works on my dev environment.
