Chromium example
Im looking to use a full feature browser, especially around webrtc support, most likely chromium, or possibly firefox, in something like a kiosk mode.
This seems to have been accomplished a few times over the years but none of these seem to work anymore:
Chromium doesnt appear to successfully start or find X?
[Logs]    [2/18/2019, 7:12:35 PM] [main] Adding user pi to group video
[Logs]    [2/18/2019, 7:12:35 PM] [main] root@ec2468a:/usr/src/app# hostname: No address associated with hostname
[Logs]    [2/18/2019, 7:12:35 PM] [main] xauth:  file /home/pi/.Xauthority does not exist
[Logs]    [2/18/2019, 7:12:36 PM] [main] xauth: (stdin):1:  bad display name "ec2468a:0" in "add" command
[Logs]    [2/18/2019, 7:12:36 PM] [main] /etc/X11/xinit/xserverrc: 3: exec: /usr/bin/X: not found
[Logs]    [2/18/2019, 7:12:51 PM] [main] xinit: giving up
[Logs]    [2/18/2019, 7:12:51 PM] [main] xinit: unable to connect to X server: Connection refused
[Logs]    [2/18/2019, 7:12:51 PM] [main] xinit: server error
[Logs]    [2/18/2019, 7:12:51 PM] [main] xauth: (argv):1:  bad display name "ec2468a:0" in "remove" command
Firefox Comes up in X with a firefox has crashed window
In the meantime Ive been pointed at an electron implementation but thats not super ideal for me, I am looking for the chromium driver set.
However Im looking to see if theres some modern wizardry around an Xorg server in that dockerfile I can figure out.
If anyone has any more pointers or links Any help appreciated.
Hey there @jacobrosenthal
Can you take a look at https://github.com/balena-io-playground/x11-window-manager
You have to modify the Dockerfile to install chromium, and uncomment line 29.
Also change the autostart code to run chromium.
Let me know if it works.
Cheers
@jacobrosenthal - check out my repo here https://github.com/willswire/timestations
I ended up getting linked to jayatvars/balena-chromium-kiosk from @jayatvars and its working great so far.
Thanks all!
