It was working a moment ago. I haven’t changed anything but the code.
Pushes fail with the following error:
whmountains@git.balena-cloud.com: Permission denied (publickey,keyboard-interactive).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Or this error:
Counting objects: 4, done.
Delta compression using up to 8 threads.
Compressing objects: 100% (4/4), done.
Writing objects: 100% (4/4), 614 bytes | 614.00 KiB/s, done.
Total 4 (delta 3), reused 0 (delta 0)
Error: Authorization failed. Status code: 404, body: <!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Not Found</pre>
</body>
</html>
remote: authorization request failed Error: Authorization failed. Status code: 404, body: <!DOCTYPE html>
remote: <html lang="en">
remote: <head>
remote: <meta charset="utf-8">
remote: <title>Error</title>
remote: </head>
remote: <body>
remote: <pre>Not Found</pre>
remote: </body>
remote: </html>
remote:
remote: at /usr/src/app/node_modules/@resin/resin-jwt/index.js:110:15
remote: at tryCatcher (/usr/src/app/node_modules/bluebird/js/release/util.js:16:23)
remote: at Promise._settlePromiseFromHandler (/usr/src/app/node_modules/bluebird/js/release/promise.js:509:35)
remote: at Promise._settlePromise (/usr/src/app/node_modules/bluebird/js/release/promise.js:569:18)
remote: at Promise._settlePromise0 (/usr/src/app/node_modules/bluebird/js/release/promise.js:614:10)
remote: at Promise._settlePromises (/usr/src/app/node_modules/bluebird/js/release/promise.js:694:18)
remote: at Promise._fulfill (/usr/src/app/node_modules/bluebird/js/release/promise.js:638:18)
remote: at PromiseArray._resolve (/usr/src/app/node_modules/bluebird/js/release/promise_array.js:126:19)
remote: at PromiseArray._promiseFulfilled (/usr/src/app/node_modules/bluebird/js/release/promise_array.js:144:14)
remote: at PromiseArray._iterate (/usr/src/app/node_modules/bluebird/js/release/promise_array.js:114:31)
remote: at PromiseArray.init [as _init] (/usr/src/app/node_modules/bluebird/js/release/promise_array.js:78:10)
remote: at Promise._settlePromise (/usr/src/app/node_modules/bluebird/js/release/promise.js:566:21)
remote: at Request._callback (/usr/src/app/node_modules/bluebird/js/release/nodeback.js:45:21)
remote: at Request.self.callback (/usr/src/app/node_modules/request/request.js:185:22)
remote: at emitTwo (events.js:126:13)
remote: at Request.emit (events.js:214:7)
remote: at Request.<anonymous> (/usr/src/app/node_modules/request/request.js:1161:10)
remote: at emitOne (events.js:116:13)
remote: at Request.emit (events.js:211:7)
remote: at IncomingMessage.<anonymous> (/usr/src/app/node_modules/request/request.js:1083:12)
remote: at Object.onceWrapper (events.js:313:30)
remote: at emitNone (events.js:111:20)
remote: at IncomingMessage.emit (events.js:208:7)
remote: at endReadableNT (_stream_readable.js:1064:12)
remote: at _combinedTickCallback (internal/process/next_tick.js:139:11)
remote: at process._tickCallback (internal/process/next_tick.js:181:9)
remote: Authorization failed. Status code: 404, body: <!DOCTYPE html>
remote: <head>
remote: </head>
remote: <body>
remote: </body>
remote: </html>
remote: Error: Authorization failed. Status code: 404, body: <!DOCTYPE html>
remote: <head>
remote: </head>
remote: <body>
remote: </body>
remote: </html>
remote:
remote:
To git.balena-cloud.com:whmountains/sensorpi-staging.git
! [remote rejected] master -> master (hook declined)
error: failed to push some refs to 'whmountains@git.balena-cloud.com:whmountains/sensorpi-staging.git'
The dashboard is showing intermittent “not found” errors.
