Similar to the post by eversteeg Unable to push basicstation - Product support - balenaForums
I tried following the tutorial things academy summer school on Youtube to set up my TTN gateway via baleana and add wifi-connect. I am using a Raspberry pi 3 and a RAK2245. I was able to connect to TTN but I am getting the same error as the post I referenced when trying to push the wifi-connect docker like how you demonstrated in this video, (135) The Things Summer Academy - Gateway Workshop - YouTube.
I get the following error:
Error: The command ‘/bin/sh -c make platform=rpi variant=std arch=armv7hf’ returned a non-zero code: 2
My output is listed below
[basicstation] Step 1/11 : FROM balenalib/raspberrypi3-debian:buster-build as builder
[basicstation] ---> 9f6d059e9bd0
[basicstation] Step 2/11 : WORKDIR /usr/src/app
[basicstation] Using cache
[basicstation] ---> f3bda7951e9a
[basicstation] Step 3/11 : COPY . .
[basicstation] ---> 4929b51df707
[basicstation] Step 4/11 : RUN make platform=rpi variant=std arch=armv7hf
[basicstation] ---> Running in 6a69606ff499
[basicstation] mkdir -p build-local/bin
[basicstation] gcc -std=gnu11 -Isrc -DCFG_prog_crc32 src/crc32.c -o build-local/bin/crc32
[basicstation] gcc -std=gnu11 -Isrc -DCFG_prog_genkwcrcs src/genkwcrcs.c -o build-local/bin/genkwcrcs
[basicstation] build-local/bin/genkwcrcs $(cat src/kwlist.txt | sed -e '/^#/d;s/[ \t]\+#.*//') > build-local/temp-kwcrc.h
[basicstation] mv build-local/temp-kwcrc.h src/kwcrc.h
[basicstation] platform=rpi variant=std make -C deps/mbedtls
[basicstation] make[1]: Entering directory '/usr/src/app/deps/mbedtls'
[basicstation] platform=rpi variant=std ./prep.sh
[basicstation] /bin/sh: 1: ./prep.sh: Permission denied
[basicstation]
[basicstation] make[1]: *** [makefile:55: platform-rpi] Error 126
[basicstation]
[basicstation] make[1]: Leaving directory '/usr/src/app/deps/mbedtls'
[basicstation] make: *** [makefile:67: deps/mbedtls] Error 2
[basicstation]
[basicstation] Removing intermediate container 6a69606ff499
[basicstation] The command '/bin/sh -c make platform=rpi variant=std arch=armv7hf' returned a non-zero code: 2
[Info] Uploading images
[Error] Service: basicstation
[Error] Error: The command '/bin/sh -c make platform=rpi variant=std arch=armv7hf' returned a non-zero code: 2
[Info] Built on 0602a6e
Remote build failed
In the original post, the user solved this issue by doing it on a Mac. I do not have a mac and I am using Windows with balena CLI like the original poster. Is there a workaround to push from a Windows machine?
