I am trying to flash a balena-os/balena-jetson image I built to the Jetson AGX Developer kit.
I am using balena-os/jetson-flash tool as follows:
#~/jetson-flash$ bin/cmd.js -f balena.img -m jetson-xavier
Consistency check done for /tmp/14352/Linux_for_Tegra
Saved in /tmp/14352
Successfully generated hash
Checking resin cache
Cache image check done
Extracting partition kernel from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition kernel_b from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition kernel-dtb from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition kernel-dtb_b from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition resin-boot from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition resin-rootA from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition resin-rootB from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition resin-state from /tmp/14352/resin/img to /tmp/14352/resin
Extracting partition resin-data from /tmp/14352/resin/img to /tmp/14352/resin
# L4T BSP Information:
# R32 , REVISION: 4.2
**Error: probing the target board failed. **
** Make sure the target board is connected through **
** USB port and is in recovery mode.**
I have tried both the jetson-xavier target as well as the jetson-xavier-nx-devkit-emmc - same problem with both.
I am quite positive the dev kit is in recovery mode as I followed the instructions and
- the light indicating recovery mode is on
- the device shows up in ‘lsusb’ as
Bus 001 Device 004: ID 0955:7019 NVIDIA Corp. APX - dmesg indicates the detection of the device
[ 1801.693222] usb 1-2: new high-speed USB device number 5 using xhci_hcd
[ 1801.842262] usb 1-2: New USB device found, idVendor=0955, idProduct=7019, bcdDevice= 1.02
[ 1801.842267] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1801.842271] usb 1-2: Product: APX
[ 1801.842274] usb 1-2: Manufacturer: NVIDIA Corp. - I am using the provided usb cable plugged into the specified usb port (next to the led)
I have successfully used the same version of balena-os/jetson-flash tool to flash the same image to the Connect Tech Rogue AGX Dev Kit https://connecttech.com/product/rogue-carrier-nvidia-jetson-agx-xavier/
Of course the image is not correct for that carrier board BUT it flashed and booted at least.
The only similar thread in these forums I found was here: Flashing Jetson TX2 via USB
There the commenter sees the same output that I do and it appears they edit one of the xml files and the issue goes away.
max@Ritter:~/jetson-flash$ cd workdir/
max@Ritter:~/jetson-flash/workdir$ ls
jetson-flash-artifacts
max@Ritter:~/jetson-flash/workdir$ cd jetson-flash-artifacts/
max@Ritter:~/jetson-flash/workdir/jetson-flash-artifacts$ sudo nano flas^C
max@Ritter:~/jetson-flash/workdir/jetson-flash-artifacts$ cd resin/
max@Ritter:~/jetson-flash/workdir/jetson-flash-artifacts/resin$ sudo nano flash.xml
max@Ritter:~/jetson-flash/workdir/jetson-flash-artifacts/resin$ cd …
max@Ritter:~/jetson-flash/workdir/jetson-flash-artifacts$ cd …
max@Ritter:~/jetson-flash/workdir$ cd …
max@Ritter:~/jetson-flash$ sudo ./bin/cmd.js -p -o ./workdir/ -m jetson-nano-emmc -f balena_dev.img
Please advise.
