hello i tried to flash an image to my drive but an error pops up:Command failed: fltmc
i have tried different drives and images i uninstalled and installed again but it doesn’t wotk
Hi, could you take a look at this forum post Writing image to a SD-card fails - #4 by BerndR56 to see if it’s the same issue as yours?
If not, we can continue debugging here.
Perhaps you have a problem with your anti-virus software. You should disable this software during the time you flash the sd-card. Also please disable anti-ransom software and have a look to other software which starts after powerring up your system. My problem was the Kaspersky software.
