I have multiple private docker images on a docker hub registry.
When I do a docker pull it works without problems.
However, when I try to deploy a release with my docker-compose.yml which contains my services I get an error
(HTTP code 500) server error - Head "https://registry-1.docker.io/v2/xxxx": unauthorized: incorrect username or password
To deploy I simply use
balena deploy xxxx/xxx --registry-secrets ./registry-secrets.yml
The docker image exists, and my docker-hub credentials are correct since I can do a docker pull
I’m using balena cli version 17.4.5 and docker version 24.0.5.
Any ideas
