Can't deploy balenair to pi zero 2 w
Hello, trying to deploy a pi zero 2 w with balenair and I get the following in the release log.
Step 1/7 : FROM balenalib/raspberrypi0-2w-64-ubuntu-python:3.8-bionic-build-20210826
manifest for balenalib/raspberrypi0-2w-64-ubuntu-python:3.8-bionic-build-20210826 not found: manifest unknown: manifest unknown
Hello @mattceh first of all welcome to the balena community!
Let me ask internally with the balenair team to see why is this happening. Did you try with another base image (e.g. build-20241017) ?
I also have seen that you opened a github issue in the repo! Thanks
Let us know if you can find a solution!
Hello, you should be able to create your fleet using the “Raspberry Pi 3 (using 64 bit OS)” device type, and then use “add device” to add a “Raspberry Pi Zero 2W (64 bit)” device to the fleet. Flash your Pi Zero 2W with that image and boot and it should download and run the balenAir services. Let us know if that works for you.
Hi, yes that did work. Services started and I had a successful deployment. However, it would lose network connection during service downloading and installing. I had to reboot it several times before all the services were running. After it was running for a couple hours I had to disconnect power and then upon rebooting it could not reload the display properly. So, while it’s better than before, I still have some issues.
Once the services have downloaded and all are running, the balenAir should be able to operate without an internet connection. Are you seeing any errors in the logs when the display is not reloading properly?
