I am trying to use balenaOS for the first time and I’m following this tutorial https://www.balena.io/os/docs/beaglebone-black/getting-started/
I connected my beaglebone with a ethernet cable to the local network.
However, when I try to ping the board with the following command it doesn’t work
ping resin.local
I suspected that it might be because of resin name change to balena, so I also tried:
ping balena.local
Still didn’t work.
How can I connect to the board?
Best regards,
Gustavo
