hello everybody,
this is my first post here… I want to evaluate balena os on a beaglebone black but failed to get it up and running wirh the tutorial on https://www.balena.io/os/docs/beaglebone-black/getting-started/
- with production image the device isn’t starting at all
- with development image the device starts, but it’s not possible to connect by ssh and after a 2-3 minutes the device shuts down by itself - section of serial log below
can anypody help here?
thanks
michael
<27>M<\r><27>[K[ <27>[0;31m*<27>[0;1;31m*<27>[0m<27>[0;31m* <27>[0m] A start job is running for Resin in…sher service (2min 25s / no limit)<\r>
<\n>
<27>M<\r><27>[K[ <27>[0;31m*<27>[0;1;31m*<27>[0m<27>[0;31m* <27>[0m] A start job is running for Resin in…sher service (2min 26s / no limit)<\r>
<\n>
<27>M<\r><27>[K[ <27>[0;31m*<27>[0;1;31m*<27>[0m<27>[0;31m*<27>[0m] A start job is running for Resin in…sher service (2min 26s / no limit)<\r>
<\n>
<27>M<\r><27>[K[ <27>[0;31m*<27>[0;1;31m*<27>[0m] A start job is running for Resin in…sher service (2min 27s / no limit)<\r>
<\n>
<27>M<\r><27>[K[ <27>[0;31m*<27>[0m] A start job is running for Resin in…sher service (2min 27s / no limit)<\r>
<\n>
<\n>
<27>M<\r><27>[K[ <27>[0;31m*<27>[0;1;31m*<27>[0m<27>[0;31m*<27>[0m] A start job is running for Resin in…sher service (2min 28s / no limit)<\r>
<\n>
<27>M<\r><27>[K[ <27>[0;31m*<27>[0;1;31m*<27>[0m<27>[0;31m* <27>[0m] A start job is running for Resin in…sher service (2min 28s / no limit)<\r>
<\n>
<27>M<\r><27>[K[ <27>[0;31m*<27>[0;1;31m*<27>[0m<27>[0;31m* <27>[0m] A start job is running for Resin in…sher service (2min 29s / no limit)<\r>
<\n>
<27>M<\r><27>[K[<27>[0;31m*<27>[0;1;31m*<27>[0m<27>[0;31m* <27>[0m] A start job is running for Resin in…sher service (2min 29s / no limit)<\r>
<\n>
<27>M<\r><27>[K[<27>[0;1;31m*<27>[0m<27>[0;31m* <27>[0m] A start job is running for Resin in…sher service (2min 30s / no limit)<\r>
<\n>
<27>M<\r><27>[K[<27>[0m<27>[0;31m* <27>[0m] A start job is running for Resin in…sher service (2min 30s / no limit)<\r>
<\n>
<27>M<\r><27>[K[<27>[0;32m OK <27>[0m] Stopped target <27>[0;1;39mRemote File Systems<27>[0m.<\r>
<\n>
<27>[K[<27>[0;32m OK <27>[0m] Stopped target <27>[0;1;39mSound Card<27>[0m.<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped target <27>[0;1;39mTimers<27>[0m.<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped <27>[0;1;39mDaily Cleanup of Temporary Directories<27>[0m.<\r>
<\n>
[<27>[0;32m OK <27>[0m] Closed <27>[0;1;39mLoad/Save RF Kill Switch Status /dev/rfkill Watch<27>[0m.<\r>
<\n>
Stopping <27>[0;1;39mFlasher bind mount for /etc/openvpn<27>[0m…<\r>
<\n>
Stopping <27>[0;1;39mFlasher bind mount for /home/root/.rnd<27>[0m…<\r>
<\n>
Stopping <27>[0;1;39mFlasher bind moun…hare/ca-certificates/balena<27>[0m…<\r>
<\n>
Stopping <27>[0;1;39mFlasher bind mount for /var/lib/bluetooth<27>[0m…<\r>
<\n>
Stopping <27>[0;1;39mLoad/Save Random Seed<27>[0m…<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped <27>[0;1;39mPeriodic check for configuration changes<27>[0m.<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped <27>[0;1;39mPeriodic vacuum of journald logs<27>[0m.<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped target <27>[0;1;39mLogin Prompts<27>[0m.<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped target <27>[0;1;39mSystem Time Synchronized<27>[0m.<\r>
<\n>
Stopping <27>[0;1;39mModem Manager<27>[0m…<\r>
<\n>
Stopping <27>[0;1;39mAvahi mDNS/DNS-SD Stack<27>[0m…<\r>
<\n>
Stopping <27>[0;1;39mGetty on tty1<27>[0m…<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped <27>[0;1;39mOS SSH keys<27>[0m.<\r>
<\n>
Stopping <27>[0;1;39mFlasher bind mount for /home/root/.ssh<27>[0m…<\r>
<\n>
[<27>[0;32m OK <27>[0m] Stopped <27>[0;1;39mudev rules configuration from config.json<27>[0m.<\r>
<\n>
Stopping <27>[0;1;39mFlasher bind mount for /etc/udev/rules.d<27>[0m…
