Cannot sync environment variable in local mode
I’m trying to work in local mode but I can’t figure out how to set environment variables.
I know they can be added manually to .resin-sync.yml but I can’t find any documentation about the correct format to use.
I’ve tried to add using resin-cli but I can’t seem to sync it to the device. I added the env with:
sudo resin env add URL 'http://myhost.home/' --device <my-uuid>
And I can see it:
$ sudo resin envs --device <my-uuid>
ID    NAME VALUE
45995 URL  http://myhost.home/
But when I try to sync I get an error:
$ sudo resin sync --device <my-uuid>
Getting information for device: <my-uuid>
Got application container info.
resin sync failed. ResinRequestError: Request error: App not found
If you need help, don't hesitate in contacting us at:
  GitHub: https://github.com/resin-io/resin-cli/issues/new
  Forums: https://forums.balena.io
I’m in the local application folder with the .resin-sync.yml file.
Am I doing something wrong or is there a problem with my configuration?
I managed to get this working by guessing the correct format for the environment variable in .resin-sync.yml (it’s just yaml at the end of the day)
Example in case anyone else finds this, since it isn’t in the docs:
  environment:
    - 'URL=http://myhost.home/'
Then I did a resin local push to get it onto the actual device.
