If I call the below against a multi-container device it ends up adding as a service variable rather than device-wide.
Is this by design and am I missing something?
@CameronDiver I’ve just read the CLI documentation again and it is indeed mentioned: “At the moment the CLI doesn’t fully support multi-container applications, so the following commands will only set service variables for the first service in your application.” so that clears it up.
