Hey. First timer here with balena and lovin’ it so far. One question. I notice on Spotify that my device comes up as…
And that librespot’s config is set to…
# Set the device broadcast name for Spotify
if [[ -z "$DEVICE_NAME" ]]; then
DEVICE_NAME=$(printf "balenaSound Spotify %s" $(hostname | cut -c -4))
fi
Any idea on how I can change this? I’d like Spotify to show BLUETOOTH_DEVICE_NAME so as to control both displays with a single var.
Thanks.
Hi there – welcome to the forums! Glad to hear you’re enjoying things.
Taking a look at the code, I think that the only place I can find the variable BLUETOOTH_DEVICE_NAME being used is in bluetooth-audio/start.sh:
if [[ "$BLUETOOTH_DEVICE_NAME" ]]; then
DEVICE_NAME="$BLUETOOTH_DEVICE_NAME"
else
DEVICE_NAME=$(printf "balenaSound %s" $(hostname | cut -c -4))
fi
fi
If I understand correctly, then, setting the DEVICE_NAME environment variable should take care of both of those things at once. Can you give that a try and let us know if it works?
All the best,
Hugh
