My hope is to use a 4 Port USB 3.0 hub loaded with usb micro sd adapters and have Etcher flash four at a time. Their big PRO machine is more than I need. Can the software do that or only one at a time?
Etcher does support multi-write so just select all the drives you want to flash in the drive selection modal and Etcher will simultaneously flash them all.
Thank you
