JetBot II.
pytorch
Made a mistake last time and the pytorch wheel wasn’t working. The reason was that I forgot specify correct CUDA arch (missing TORCH_CUDA_ARCH_LIST=5.3). It’s fixed now and wheels are available for download at the jetson-nano-1.1 release page.
Don’t use the jetson-nano-1.0 release, it doesn’t work.
balena-nanny-bot/jetbot branch
Changes
- Add missing GStreamer libraries (NVIDIA)
- Download & install IMX219-160 Camera overrides
- Install & properly configure Tegra EGL libraries
- Utilize
docker-compose.ymlto be able to addSYS_RAWIOcapability
Deployment
- Follow the README file instructions
NOTE: It’s still quite big image (not optimised yet).
[Info] ┌─────────┬────────────┬────────────────────────┐
[Info] │ Service │ Image Size │ Build Time │
[Info] ├─────────┼────────────┼────────────────────────┤
[Info] │ jetbot │ 8.57 GB │ 29 minutes, 26 seconds │
[Info] └─────────┴────────────┴────────────────────────┘
[Info] Build finished in 36 minutes, 33 seconds
wander.py
JetBot repository contains wander.py application. Your JetBot just wanders and is trying to avoid collisions.
- Download best_model.pth
First terminal:
balena ssh $UUID --host-
nvpmodel -m 1(switch to 5W mode) exitbalena ssh $UUID jetbot-
nvargus-daemon(keep it running)
root@19c80a8:/usr/src/app# nvargus-daemon
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...
Second terminal:
balena ssh $UUID jetbot- Copy the
best_model.pthfrom your computer (scp ...) python3 jetbot/jetbot/apps/wander.py ./best_model.pth
root@19c80a8:/usr/src/app# python3 jetbot/jetbot/apps/wander.py ./best_model.pth
Loading model...
Initializing camera...
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3280 H = 2464
seconds to Run = 0
Frame Rate = 21.000000
GST_ARGUS: PowerService: requested_clock_Hz=37126320
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Running...
It’s not user friendly, I know, I know, … but at least it works properly now!
Will also expose Python notebooks, so, we can train the JetBot and do everything what’s explained at the examples page.
